I am using Eclipse Version: 2018-09 (4.9.0) on a windows 10 64 bit machine.
All was working great untill today.
I tried to open a previously working binding but immediately got a number of errors.
I believe this is caused by an eclipse configuration issue but cannot work out what it is.
I then noticed the status bar had a warning for eclipse updater the error is shown below
Executing startup tasks
Java(TM) SE Runtime Environment 1.8.0_181-b13
Product org.eclipse.products.epp.package.java.latest.released
Workspace C:\Users\Mick\openhab2-master2\ws
Project com.github.openhab2.2_openhab2.master
Project com.github.openhab2.1_infra.master
Bundle org.eclipse.oomph.setup 1.10.0.v20180828-0705, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.core 1.10.0.v20180714-0556, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.git 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.jdt 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.p2 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.pde 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.projects 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Bundle org.eclipse.oomph.setup.workingsets 1.10.0.v20180706-1242, build=3640, branch=483e5aed5eb9acd355d0b88d3989653101baabf6
Performing Preference /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.argumentSuffixes
Performing Preference /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComplete.staticFinalFieldSuffixes
Performing Target Platform openHAB Target Platform
Fetching p2.index from https://dl.bintray.com/openhab/p2/openhab-core/2.4.x/ (173B)
Fetching p2.index from http://download.eclipse.org/smarthome/updates-stable/
Fetching p2.index from http://download.eclipse.org/eclipse/updates/4.6/
Fetching p2.index from http://download.eclipse.org/eclipse/updates/4.6/R-4.6-201606061100/
Fetching p2.index from http://download.eclipse.org/eclipse/updates/4.6/R-4.6.1-201609071200/
Fetching p2.index from http://download.eclipse.org/eclipse/updates/4.6/R-4.6.2-201611241400/
Fetching p2.index from http://download.eclipse.org/eclipse/updates/4.6/R-4.6.3-201703010400/
Fetching p2.index from https://dl.bintray.com/openhab/p2/openhab-deps-repo/1.0.31/ (173B)
Calculating requirements and dependencies.
Cannot complete the request. Generating details.
ERROR: org.eclipse.pde.core code=0 Problems occurred while resolving the target contents
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.util.pde.TargetPlatformUtil.activateTargetDefinition(TargetPlatformUtil.java:151)
at org.eclipse.oomph.setup.pde.impl.TargetPlatformTaskImpl.perform(TargetPlatformTaskImpl.java:293)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3334)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:3277)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:4504)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2292)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2319)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:4498)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:4496)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3268)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3243)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3143)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:575)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:701)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
ERROR: org.eclipse.equinox.p2.director code=10053 Cannot complete the install because one or more required items could not be found.
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: Eclipse SmartHome REST Support 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.rest.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: Eclipse SmartHome Item Model 0.10.0.201809210646 (org.eclipse.smarthome.model.item 0.10.0.201809210646) requires 'osgi.bundle; org.eclipse.xtext.xbase.lib 2.14.0' but it could not be found
ERROR: org.eclipse.equinox.p2.director code=1 Cannot satisfy dependency:
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse SmartHome Model Support 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.model.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.smarthome.model.item [0.10.0.201809210646,0.10.0.201809210646]
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse SmartHome REST Support 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.rest.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.smarthome.feature.runtime.model.feature.group 0.0.0
Took 6 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
Can anybody tell what’s gone wrong?
I have tried to close and open eclipse but the same keeps happening!
Many Thanks
ERROR: org.eclipse.equinox.p2.director code=0 Software being installed: Eclipse SmartHome Automation Support 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.automation.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 Missing requirement: Eclipse SmartHome Serial Transport extension for RXTX RFC2217 0.10.0.201809210646 (org.eclipse.smarthome.io.transport.serial.rxtx.rfc2217 0.10.0.201809210646) requires ‘java.package; gnu.io.rfc2217 0.0.0’ but it could not be found
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse SmartHome Automation Support 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.automation.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.smarthome.feature.runtime.core.feature.group 0.0.0
ERROR: org.eclipse.equinox.p2.director code=0 From: Eclipse SmartHome Core 0.10.0.201809210646 (org.eclipse.smarthome.feature.runtime.core.feature.group 0.10.0.201809210646)
ERROR: org.eclipse.equinox.p2.director code=0 To: org.eclipse.equinox.p2.iu; org.eclipse.smarthome.io.transport.serial.rxtx.rfc2217 [0.10.0.201809210646,0.10.0.201809210646]
Same here. Was working until I ran updates using openhabian-config.
!ENTRY org.eclipse.osgi 4 0 2018-09-29 12:22:19.370
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
at org.eclipse.emf.ecore.plugin.EcorePlugin.getWorkspaceRoot(EcorePlugin.java:1131)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.<clinit>(ExtensibleURIConverterImpl.java:393)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getURIConverter(ResourceSetImpl.java:499)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:369)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.getResource(ResourceHandler.java:350)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:326)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:231)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:435)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:260)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.smarthome.designer.ui.internal.application.Application.start(Application.java:32)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (67).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:311)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 26 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 35 more
Caused by: org.eclipse.core.internal.dtree.ObjectNotFoundException: Tree element '/config/config/transform/readme.txt' not found.
at org.eclipse.core.internal.dtree.AbstractDataTree.handleNotFound(AbstractDataTree.java:257)
at org.eclipse.core.internal.dtree.DeltaDataTree.getData(DeltaDataTree.java:585)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:50)
at org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelta(DataDeltaNode.java:47)
at org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelta(DeltaDataTree.java:88)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:816)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:815)
at org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDataTree.java:792)
at org.eclipse.core.internal.watson.ElementTree.immutable(ElementTree.java:518)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:711)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1532)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2464)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2219)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:447)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
Has anybody found a solution?
I have tried setting up a new workspace and the errors appear to have gone.
Unfortunately in the new workspace I cannot see the changes I have made to a binding I am working on and cannot see any related commits.
Fortunately I have been able to carry out the changes recommended from review, via the Github web interface.
If there is no solution I will wait for the binding to be approved and re-download (if any bugs are discovered), to ensure I stay in step.
Fingers crossed the changes will be approved soon and included to the next update
