I try to run Eclipse SmartHome Designer on Mac osSierra 10.12.2 but I got only following error
!SESSION 2016-12-25 11:07:42.625 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_111
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=pl_PL
Command-line arguments: -os macosx -ws cocoa -arch x86_64
!ENTRY org.eclipse.core.runtime 4 0 2016-12-25 11:07:48.837
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.core.runtime [2]
Unresolved requirement: Require-Bundle: javax.annotation; bundle-version=“1.1.0”; visibility:=“reexport”; resolution:=“optional"
Unresolved requirement: Require-Bundle: javax.inject; bundle-version=“1.0.0”; visibility:=“reexport”; resolution:=“optional"
Unresolved requirement: Require-Bundle: org.eclipse.equinox.common; bundle-version=”[3.6.100,4.0.0)”; visibility:=“reexport”
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:242)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:172)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:412)
at org.eclipse.osgi.launch.Equinox.start(Equinox.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:320)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:232)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
