ECMA Script: IOUtils toInputStream
since ‘org.apache.commons.*’ dependency was removed in 2020
https://github.com/openhab/openhab-addons/issues/7722
this line will not work
var input = org.apache.commons.io.IOUtils.toInputStream(content, "UTF-8");
java.lang.ClassNotFoundException: org.apache.commons.io.IOUtils.toInputStream
How can I call Java function toInputStream in ECMA Script?
Frank
There a probably several ways to fix this. However, without knowing the context why you need an inputstream an answer might be might be sub optimal. So can you provide some more context on how you use the inputstream?
Hi @hilbrand,
I’m using
var response = HttpUtil.executeUrl(httpMethod, url , timeout);
for the connection to my web service.
But I need
var response = HttpUtil.executeUrl(httpMethod, url , input, contentType, timeout);
to pass the form parameters too. ‘input’ is a string variable, so I have to convert it with toInputStream(input) to a stream, because the 3rd parameter is of type stream
possible alternative
var stream = new java.io.ByteArrayInputStream(content.getBytes("UTF-8"))
var response = HttpUtil.executeUrl(httpMethod, url , stream, contentType, timeout);
Ah make sense. I see you already found a solution with ByteArrayInputStream.
