I’m really struggling here. I’ve searched around but I cant seem to solve my problem.
I’m trying to set up my ecobee 3 thermostat. I have made a developer account and made the app on ecobees website in my thermostats portal. I copied the app key from the app and pasted it into my openhab.cfg file. Uncommented it out like i did with other bindings. Made it be a smartWrite.
I copied some of the example .items and .sitemap from the openhab getting started pages.
I am not getting the request for the PIN. Nothing ever shows up in the server logs that says I need to authenicate on ecobees website. I have changed the log file to TRACE and still. nothing. I’m so stuck!
Do you have the ecobee binding jar in your addons folder?
Do you have at least one item bound to a { ecobee="<[<id>#<property>]" }? (The reason being, the binding won’t attempt to request a PIN unless it knows it has something to do, like poll the server.)
I do have the bindings in the addons and I have an item bound as these:
Number Ecobee_Name “Room [%s]” {ecobee="<[mythermostatsnumberwashere#name]"}
Number MainFloorTemp “Main Floor temperature [%.1f °F]” { ecobee="<[mythermostatsnumberwashere#remoteSensors(MainFloor).capability(temperature).value]" }
That should be a String item, not a Number item, but I’m not sure that is the cause of the issue. Could you change it and see if it makes a difference?
Are you sure you have a sensor named MainFloor, spelled exactly that way? The thermostat itself’s name is also listed by the API as a sensor, so you could use that as well.
################################ Ecobee Binding #######################################
# the private API key issued be Ecobee to use the API (required, replace with your own)
ecobee:appkey=4************************u
# the application scope used when authorizing the binding
# choices are smartWrite,smartRead, or ems, or multiple (required, comma-separated, no spaces)
ecobee:scope=smartWrite
# Rate at which to check if poll is to run, in ms (optional, defaults to 5000)
# ecobee:granularity=5000
# Data refresh interval in ms (optional, defaults to 180000)
# ecobee:refresh=180000
# Time in ms to wait after successful update, command or action before refresh (optional, defaults to 6000)
# ecobee:quickpoll=6000
# Time in ms to allow an API request to complete (optional, defaults to 20000)
# ecobee:timeout=20000
# the temperature scale to use when sending or receiving temperatures
# optional, defaults to Fahrenheit (F)
# ecobee:tempscale=
