Ecobee binding versions
Hi there.
I am trying to setup the ecobee binding and am a bit confused. It appears there are 2 versions of the ecobee binding according to the openhab documentation. ecobee and ecobee1. I can only find a binding with a version of 1.14 in PaperUI. From what I can gather this is v1. Where can I find the newer ecobee binding that uses a things file?
Thank you.
The Ecobee v2 binding is very new, and was just recently merged. If you are not on 2.5.4 or later, I don’t think you’ll see it in Paper UI.
If you don’t want to upgrade here is the snapshot jar files.
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.ecobee/
Be sure to use the jar file and not the sources.jar.
