In OpenHAB 1, the Z-Wave door sensor worked as a Contact, and this is how I want to show it in the classic UI and in HabPanel (as OPEN/CLOSED rather than ON/OFF).
In OH2, the BINARY_SENSOR returns ONOFF so it can only be mapped to a switch. I’ve worked around this in a rule by creating a contact variable but wonder if this is a bug and I should be able to add my switch BINARY_SENSOR to a Contact variable directly.
rule "Front Door Opened"
Item frontdoor_sensor_switch changed
if(frontdoor_sensor_switch.state==ON) {
pushover(“Front door opened”)
postUpdate(frontdoor_sensor_contact, OPEN)
} else if (frontdoor_sensor_switch.state==OFF) {
postUpdate(frontdoor_sensor_contact, CLOSED)
Just added one of these and noticed that it came up as a contact not a switch, as all the rest of my door contact devices(WADWAZ-1) are Switches, myy question is, for consistency, should we change WADWAZ-1 to sensor_door? I was under the impression that Contacts were being deprecated in OH2 and they would all be Switches now. I have a couple of different types that used to be Contacts (ZW097 dry contact sensors and all my motion sensors) but changed to Switches in OH2.
I actually prefer all the devices that have an ON/OFF state to be Switches as it keeps the rules simpler to have just one type to deal with but I can see that OPEN/CLOSED is more accurate.
