Yes, I normally use the notification commands and it seems that this is working.
Note: Please use code fences to format logs - or format using the </> button. It makes reading and processing logs much much easier.
Sensor sends:
When openHAB receives:
Linking both sensor_door & alarm_tamper with COMMAND_CLASS_ALARM is visible in the database and logs and possibly the explanation why OH ignores doors being opened or closed.
I have the same issue with OH3.0.0 and Z-Wave-Device MT02648 Door/Window Contact
and channel (Sensor_door Contact) ignore the change of value 0/255.
We are talking here about a different device, please open a new topic.
Binding 2.5.11 same problem.
@chris is there any reason we canāt use the code from the 2.5.4 version that worked and paste that back in the database? Was there a large structure change?
I highly recommend reverting to the old version.
Why?
The binding uses the ALARM commands - as discussed above. These are more informative than the older style commands, and probably you need to change a config to send these commands instead of the old commands.
Strange - according to the database, it does. So either you have a different device, or the database is wrong. Maybe you can help with information to resolve this?
The database is wrong. It references (and seems to rely on) the āUpdated Manualā Tilt-ZWave-Plus-Manual-R1-04-021816kgs.pdf which is not for this device. The manual is for product type 4 (see bottom page 4). This discussion is about is product type 1, not product type 4.
I speculate that at some point TILTZWAVE2 (product type 1) was erroneously updated to reflect the characteristics from the manual for TILT-ZWAVE2.5-ECO (product type 4).
Just to be clear, before this change, the binding worked fine. The tilt state updated correctly, and the tamper alarm (when removing the cover of the device) also worked correctly.
I have not found any documentation on configuration parameters for TILTZWAVE2 to change the default behavior of the device.
Please can you provide your XML file for the device please.
Also, if you want to help improve the database, so that it works for you and others, then you can do so. I suggest that this is a better approach than just recommending not to use the binding.
Sure! Iām glad to provide my XML file for the device (I didnāt even know I had one!).
I know next to nothing about Z-Wave, so I wouldnāt want to change the database myself; thatās why Iām reporting my observations here so the experts can do the best thing with this information. I just noticed that one of the manuals referenced in the database is for the wrong device and the database seems to have been recently updated to reflect information from that incorrect manual.
The current binding is working for me just fine with the reverted tiltzwave2_0_0.xml file. I apologize if I am confusing terminology here, but the current binding (the code) works just fine. Just not the recently changed tiltzwave2_0_0.xml file from the database.
I donāt understand openHAB and Z-Wave very well, but since there seemed to be no progress on this issue for months, I was just trying to say that the old database entry seems to work fine for me and if that were changed back, I would be happy. Maybe it is no longer compatible? I donāt know. Sorry if I wasnāt clear on that or if I didnāt use the correct terminology.
<node>
<homeId>0x1853378</homeId>
<nodeId>4</nodeId>
<version>4</version>
<manufacturer>0x14a</manufacturer>
<deviceId>0x3</deviceId>
<deviceType>0x1</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_MARK</commandClass>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_ROUTING_SENSOR_BINARY</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__WAKE__UP>
<version>2</version>
<instances>1</instances>
<control>false</control>
<versionSupported>2</versionSupported>
<targetNodeId>1</targetNodeId>
<interval>14400</interval>
<minInterval>3600</minInterval>
<maxInterval>604800</maxInterval>
<defaultInterval>14400</defaultInterval>
<intervalStep>200</intervalStep>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<COMMAND__CLASS__APPLICATION__STATUS>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</COMMAND__CLASS__APPLICATION__STATUS>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<alarms>
<entry>
<alarmType>BURGLAR</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
<isGetSupported>false</isGetSupported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>2</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ROUTING</libraryType>
<protocolVersion>3.40</protocolVersion>
<applicationVersion>2.0</applicationVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>330</deviceManufacturer>
<deviceType>1</deviceType>
<deviceId>3</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>99</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<types/>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>2</int>
<int>11</int>
<int>13</int>
<int>14</int>
<int>20</int>
</nodeNeighbors>
<lastReceived>2021-03-06 11:33:48.492 UTC</lastReceived>
</node>
Perhaps database updates on existing entries should be more scrutinized.
Several devices (sensors, locks, switches) which worked with OH for many years are having configuration issues or stopped working completely within last year or so. These devices work fine on other platforms (e.g. VeraPlus and this Ecolink sensor).
Has this been addressed for OH 3.1?
Iāve come up against this issue too. I upgraded to OH 3.1 from a VeraLite and gained a few newer sensors that werenāt working but lost use of this one.
Are there plans to get this working again or is there a configuration change on the server that I need to make?
If not, Iām planning on moving the actual tilt sensor component to a door sensor that is working but Iād rather not have to do that.
Is there information I can provide to help? Iām just starting out with OH and Iām not sure where everything is yet but Iām willing to learn.
Just stumbled on this. I have 2 eco door and 2 eco tilt for several years and never had a problem at least that I know about. I do use the contact channel. Also I think they are 2.5 version if that makes a difference.
Bob
Here is my XML file. It looks pretty much the same as the one posted above.
<node>
<homeId>0xff812de7</homeId>
<nodeId>24</nodeId>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
</deviceClass>
<entry>
</entry>
<entry>
</entry>
<entry>
<types/>
</entry>
<entry>
</entry>
<entry>
<batteryLevel>100</batteryLevel>
</entry>
<entry>
<configParameters/>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>3</int>
<int>7</int>
<int>10</int>
<int>11</int>
<int>12</int>
<int>13</int>
</nodeNeighbors>
<lastReceived>2021-06-28 20:38:27.766 UTC</lastReceived>
</node>
How is your device configured? Does it send notifications or binary sensor reports (parameter 2)? A debug log might help to understand also.
I see binary sensor reports: Sensor Binary report, type=Unknown, value=255
Log:
2021-07-05 08:46:39.681 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 08:47:26.078 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 18 03 30 03 FF B3 00 94
2021-07-05 08:47:26.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 FF B3 00
2021-07-05 08:47:26.080 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 FF B3 00
2021-07-05 08:47:26.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-07-05 08:47:26.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2021-07-05 08:47:26.082 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2021-07-05 08:47:26.083 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2021-07-05 08:47:26.084 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 08:47:26.084 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2021-07-05 08:47:26.084 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=255
2021-07-05 08:47:26.085 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2021-07-05 08:47:26.085 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2021-07-05 08:47:26.086 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2021-07-05 08:47:26.086 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@13ea175.
2021-07-05 08:47:26.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-07-05 08:47:26.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 08:47:26.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 08:47:34.078 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 18 03 30 03 00 B1 00 69
2021-07-05 08:47:34.080 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 00 B1 00
2021-07-05 08:47:34.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 00 B1 00
2021-07-05 08:47:34.081 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-07-05 08:47:34.082 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2021-07-05 08:47:34.083 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2021-07-05 08:47:34.083 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2021-07-05 08:47:34.084 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 08:47:34.084 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2021-07-05 08:47:34.085 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=0
2021-07-05 08:47:34.085 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2021-07-05 08:47:34.086 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2021-07-05 08:47:34.086 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2021-07-05 08:47:34.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1dc9fe.
2021-07-05 08:47:34.087 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-07-05 08:47:34.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 08:47:34.088 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
As above though - how is your device configured to send reports?
Parameter 2 does not seem to change. No matter what I try to set it to (1, 255, etc.) the āPENDINGā tag does not go away.
Iāve tried saving the change, and then waking up the sensor with the tamper switch, waking the sensor by tilting it, removing and replacing the battery, reinitializing the device (I can only do this once as this choice disappears after the first selection.)
Below are logs.
Change parameter 2 to 255, hit save, device is asleep:
2021-07-05 16:10:54.767 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-07-05 16:10:54.767 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-07-05 16:10:54.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-07-05 16:10:54.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:10:54.768 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:11:07.052 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update received
2021-07-05 16:11:07.055 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored config_1_1 to 0 (BigDecimal)
2021-07-05 16:11:07.056 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update set config_2_1 to 255 (BigDecimal)
2021-07-05 16:11:07.056 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 24: Creating new message for application command CONFIGURATION_SET
2021-07-05 16:11:07.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 16:11:07.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-07-05 16:11:07.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 172 priority from Config to Immediate
2021-07-05 16:11:07.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2021-07-05 16:11:07.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 172 to queue - size 8
2021-07-05 16:11:07.058 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:11:07.059 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 24: Creating new message for application command CONFIGURATIONCMD_GET
2021-07-05 16:11:07.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 16:11:07.059 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-07-05 16:11:07.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 173 priority from Config to Immediate
2021-07-05 16:11:07.059 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2021-07-05 16:11:07.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 173 to queue - size 9
2021-07-05 16:11:07.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:11:07.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored action_reinit to false (Boolean)
2021-07-05 16:11:07.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored wakeup_node to 1 (BigDecimal)
2021-07-05 16:11:07.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored wakeup_interval to 14400 (BigDecimal)
2021-07-05 16:11:07.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_1 to [controller] (ArrayList)
2021-07-05 16:11:07.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored node_id to 24 (BigDecimal)
2021-07-05 16:11:07.061 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Configuration update ignored group_2 to [] (EmptyList)
Wake up sensor with tamper switch:
2021-07-05 16:12:20.875 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0A 00 04 00 18 02 84 07 B0 00 D8
2021-07-05 16:12:20.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 02 84 07 B0 00
2021-07-05 16:12:20.878 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 02 84 07 B0 00
2021-07-05 16:12:20.878 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-07-05 16:12:20.878 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-07-05 16:12:20.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Is awake with 3 messages in the queue
2021-07-05 16:12:20.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Start sleep timer at 5000ms
2021-07-05 16:12:20.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2021-07-05 16:12:20.885 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 24: Node Status event - Node is AWAKE
2021-07-05 16:12:20.885 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2021-07-05 16:12:20.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@dd64c9.
2021-07-05 16:12:20.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2021-07-05 16:12:20.886 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:20.887 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:12:20.887 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 18 03 70 05 01 25 85 29
2021-07-05 16:12:20.888 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 0A 00 13 18 03 70 05 01 25 85 29
2021-07-05 16:12:20.888 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:20.888 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 158: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:20.889 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:20.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:20.890 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:20.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 158: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:20.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:20.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:20.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:20.896 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-07-05 16:12:20.897 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:20.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:20.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 158: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:20.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:20.898 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 158: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:20.899 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:20.899 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2021-07-05 16:12:20.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 158: Advanced to WAIT_REQUEST
2021-07-05 16:12:20.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 158: Transaction not completed
2021-07-05 16:12:20.899 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:20.900 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:20.996 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 85 00 00 0A 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 01 00 00 C2
2021-07-05 16:12:20.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 0A 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 01 00 00
2021-07-05 16:12:21.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 0A 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 01 00 00
2021-07-05 16:12:21.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 158: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:21.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:21.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 158: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 133
2021-07-05 16:12:21.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 158: (Callback 133)
2021-07-05 16:12:21.002 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-07-05 16:12:21.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 158: callback 133
2021-07-05 16:12:21.003 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 0A 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 01 00 00
2021-07-05 16:12:21.004 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 133, Status = Transmission complete and ACK received(0)
2021-07-05 16:12:21.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 158: Advanced to WAIT_DATA
2021-07-05 16:12:21.005 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 158: Transaction not completed
2021-07-05 16:12:21.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:21.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:21.037 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0B 00 04 00 18 03 22 02 00 B1 00 7A
2021-07-05 16:12:21.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 22 02 00 B1 00
2021-07-05 16:12:21.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 22 02 00 B1 00
2021-07-05 16:12:21.039 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2021-07-05 16:12:21.040 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:GET_CONFIGURATION)
2021-07-05 16:12:21.040 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_APPLICATION_STATUS, endpoint 0
2021-07-05 16:12:21.040 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 16:12:21.040 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_APPLICATION_STATUS V0 APPLICATION_REJECTED_REQUEST
2021-07-05 16:12:21.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2021-07-05 16:12:21.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@110e44f.
2021-07-05 16:12:21.041 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Command NOT verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@110e44f.
2021-07-05 16:12:21.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2021-07-05 16:12:21.042 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:21.043 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:23.380 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 3 Messages waiting, state GET_CONFIGURATION
2021-07-05 16:12:25.879 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 3 Messages waiting, state GET_CONFIGURATION
2021-07-05 16:12:25.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: No more messages, go back to sleep
2021-07-05 16:12:25.881 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 24: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2021-07-05 16:12:25.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 16:12:25.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2021-07-05 16:12:25.882 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1170b37
2021-07-05 16:12:25.883 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 174 priority from Immediate to Immediate
2021-07-05 16:12:25.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2021-07-05 16:12:25.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 174 to queue - size 9
2021-07-05 16:12:25.884 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:26.005 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 24: TID 158: Timeout at state WAIT_DATA. 2 retries remaining.
2021-07-05 16:12:26.006 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 158: Transaction CANCELLED
2021-07-05 16:12:26.006 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-07-05 16:12:26.006 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:158 CANCELLED
2021-07-05 16:12:26.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:12:26.007 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 158: Transaction event listener: DONE: CANCELLED ->
2021-07-05 16:12:26.008 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node Init response (4) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@52f6ab
2021-07-05 16:12:26.008 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 13 18 05 70 04 02 01 FF 25 95 C5
2021-07-05 16:12:26.008 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: No data from device, but it was ACK'd. Possibly not supported? (Try 4)
2021-07-05 16:12:26.009 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node Init transaction retries exceeded
2021-07-05 16:12:26.009 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 0C 00 13 18 05 70 04 02 01 FF 25 95 C5
2021-07-05 16:12:26.009 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node advancer: GET_CONFIGURATION - checking config_2_1 - config
2021-07-05 16:12:26.009 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: Node advancer: GET_CONFIGURATION - checking config_2_1 - index 2
2021-07-05 16:12:26.009 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:26.009 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 24: Creating new message for application command CONFIGURATIONCMD_GET
2021-07-05 16:12:26.010 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 24: ZWaveCommandClassTransactionPayload - send to node
2021-07-05 16:12:26.010 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 172: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.010 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2021-07-05 16:12:26.011 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2021-07-05 16:12:26.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@1ce652b
2021-07-05 16:12:26.011 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:26.011 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 175 priority from Config to Immediate
2021-07-05 16:12:26.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2021-07-05 16:12:26.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:26.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Transaction already in queue - removed original
2021-07-05 16:12:26.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:26.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 175 to queue - size 8
2021-07-05 16:12:26.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 172: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:26.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:26.013 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:26.014 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:26.017 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-07-05 16:12:26.018 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.018 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.018 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 172: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.019 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:26.019 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 172: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.019 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.019 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2021-07-05 16:12:26.019 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 172: Advanced to WAIT_REQUEST
2021-07-05 16:12:26.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 172: Transaction not completed
2021-07-05 16:12:26.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:26.020 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:26.154 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 95 00 00 0E 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 02 00 00 D5
2021-07-05 16:12:26.156 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=149, payload=95 00 00 0E 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 02 00 00
2021-07-05 16:12:26.157 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=149, payload=95 00 00 0E 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 02 00 00
2021-07-05 16:12:26.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 172: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:26.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 172: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 149
2021-07-05 16:12:26.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 172: (Callback 149)
2021-07-05 16:12:26.159 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-07-05 16:12:26.159 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 172: callback 149
2021-07-05 16:12:26.160 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=149, payload=95 00 00 0E 01 B3 7F 7F 7F 7F 01 01 03 0B 00 00 00 02 02 00 00
2021-07-05 16:12:26.160 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 149, Status = Transmission complete and ACK received(0)
2021-07-05 16:12:26.161 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 172: Transaction COMPLETED
2021-07-05 16:12:26.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Response processed after 151ms
2021-07-05 16:12:26.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 172: Transaction completed
2021-07-05 16:12:26.161 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:172 DONE
2021-07-05 16:12:26.162 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-07-05 16:12:26.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:26.163 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:12:26.164 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 18 02 84 08 25 96 C0
2021-07-05 16:12:26.164 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 09 00 13 18 02 84 08 25 96 C0
2021-07-05 16:12:26.165 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:26.165 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 174: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:26.166 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:26.166 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:26.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:26.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 174: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:26.167 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:26.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:26.168 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:26.173 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-07-05 16:12:26.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.174 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 174: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:26.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:26.175 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 174: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:26.175 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:26.176 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2021-07-05 16:12:26.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 174: Advanced to WAIT_REQUEST
2021-07-05 16:12:26.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 174: Transaction not completed
2021-07-05 16:12:26.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:26.177 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:31.177 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 24: TID 174: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-07-05 16:12:31.178 [DEBUG] [sactionManager$ZWaveTransactionTimer] - Aborting Transaction!
2021-07-05 16:12:31.179 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 174: Transaction ABORTED
2021-07-05 16:12:31.179 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2021-07-05 16:12:31.180 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
2021-07-05 16:12:31.180 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:31.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:31.181 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:31.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:31.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:31.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 174: [ABORTED] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:31.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:31.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:31.183 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:33.672 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 96 01 02 EE 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0D 0A 18 EA
2021-07-05 16:12:33.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=1, callback=150, payload=96 01 02 EE 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0D 0A 18
2021-07-05 16:12:33.674 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=1, callback=150, payload=96 01 02 EE 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0D 0A 18
2021-07-05 16:12:33.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 174: [ABORTED] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:33.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:33.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 174: [ABORTED] priority=Immediate, requiresResponse=true, callback: 150
2021-07-05 16:12:33.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 174: (Callback 150)
2021-07-05 16:12:33.675 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-07-05 16:12:33.675 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 174: callback 150
2021-07-05 16:12:33.676 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=1, callback=150, payload=96 01 02 EE 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0D 0A 18
2021-07-05 16:12:33.676 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 150, Status = Transmission complete, no ACK received(1)
2021-07-05 16:12:33.676 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: WAKE_UP_NO_MORE_INFORMATION. Treated as ACK.
2021-07-05 16:12:33.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 174: Transaction not completed
2021-07-05 16:12:33.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:33.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:43.179 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 24: TID 174: Timeout at state ABORTED. 3 retries remaining.
2021-07-05 16:12:43.180 [DEBUG] [sactionManager$ZWaveTransactionTimer] - TID 174: Transaction is current transaction, so clearing!!!!!
2021-07-05 16:12:43.180 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 174: Transaction CANCELLED
2021-07-05 16:12:43.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-07-05 16:12:43.181 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:174 CANCELLED
2021-07-05 16:12:43.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:12:43.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 174: Transaction event listener: DONE: CANCELLED ->
2021-07-05 16:12:43.182 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Went to sleep COMPLETE
2021-07-05 16:12:43.183 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 18 03 70 05 02 25 97 38
2021-07-05 16:12:43.183 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 0A 00 13 18 03 70 05 02 25 97 38
2021-07-05 16:12:43.184 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:43.184 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 175: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:43.185 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:43.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:43.186 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:43.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 175: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:43.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:43.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:43.187 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:43.192 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2021-07-05 16:12:43.193 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:43.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:43.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 175: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:43.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:43.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 175: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:43.195 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2021-07-05 16:12:43.195 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2021-07-05 16:12:43.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 175: Advanced to WAIT_REQUEST
2021-07-05 16:12:43.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 175: Transaction not completed
2021-07-05 16:12:43.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:43.196 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:48.195 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 24: TID 175: Timeout at state WAIT_REQUEST. 3 retries remaining.
2021-07-05 16:12:48.196 [DEBUG] [sactionManager$ZWaveTransactionTimer] - Aborting Transaction!
2021-07-05 16:12:48.196 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 175: Transaction ABORTED
2021-07-05 16:12:48.196 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
2021-07-05 16:12:48.197 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
2021-07-05 16:12:48.198 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2021-07-05 16:12:48.198 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:48.198 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2021-07-05 16:12:48.199 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:48.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2021-07-05 16:12:48.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 175: [ABORTED] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:48.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2021-07-05 16:12:48.200 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:48.201 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2021-07-05 16:12:49.822 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 13 97 01 02 97 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0A 0B 18 94
2021-07-05 16:12:49.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=1, callback=151, payload=97 01 02 97 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0A 0B 18
2021-07-05 16:12:49.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=1, callback=151, payload=97 01 02 97 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0A 0B 18
2021-07-05 16:12:49.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 175: [ABORTED] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:49.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2021-07-05 16:12:49.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 175: [ABORTED] priority=Immediate, requiresResponse=true, callback: 151
2021-07-05 16:12:49.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 175: (Callback 151)
2021-07-05 16:12:49.827 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2021-07-05 16:12:49.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 175: callback 151
2021-07-05 16:12:49.827 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=1, callback=151, payload=97 01 02 97 00 7F 7F 7F 7F 7F 01 01 07 00 00 00 00 02 0A 0B 18
2021-07-05 16:12:49.828 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 151, Status = Transmission complete, no ACK received(1)
2021-07-05 16:12:49.828 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 175: Transaction CANCELLED
2021-07-05 16:12:49.828 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2021-07-05 16:12:49.828 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: CANCEL while sending message. Requeueing - 2 attempts left!
2021-07-05 16:12:49.829 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 175: Transaction RESET with 2 retries remaining.
2021-07-05 16:12:49.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2021-07-05 16:12:49.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 175 to queue - size 7
2021-07-05 16:12:49.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2021-07-05 16:12:49.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 175: Transaction not completed
2021-07-05 16:12:49.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2021-07-05 16:12:49.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
