Ecolink Tilt-zwave2 No longer working
I had the Ecolink Tilt-Zwave2 working prior to an upgrade. Now on version 2.5.8 and 2.5.9, the state no longer changes. It joined the network and initialised without any problems.
In version 2.5.4 the exposed channel in Paper was: (this worked)
Binary Sensor
zwave:device:ae19e8d6:node20:sensor_door
Contact
Now versions 2.5.8-9 show: (this doesn’t work)
Door State [Deprecated]
zwave:device:161a521c:node49:sensor_door
Contact
but the channel gets set to Open and never changes.
In the z-wave debug I can see the status changes:
NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
NODE 49: Sensor Binary report, type=Unknown, value=0
NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
NODE 49: Commands processed 1.
and…
NODE 49: Sensor Binary report, type=Unknown, value=255
NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
The Tamper Alarm Channel does not update and remains at ON. The Battery Level reports 100…but I wont know if it changes for while. :slight_smile:
I have a Ecolink Tilt-ZWave2.5 that works flawlessly after the update, but the 2.0 does not. I am very concerned because I have 6 of the version 2 devices running on another network that I have not updated yet. Digging through the code for these devices in the z-wave database, I found the code for the 2.0 device had a major update to make the code resemble the 2.5 device sometime between 2.5.4 and 2.5.8.
Any ideas or help?
Thank you in advance and thank you, Chris, for all the work you have in the z-wave library.
Is this the only stuff that is in the log file? The device should also send a notification (ALARM) when the state changes and this channel should be the one that is used by the binding. Is this sent? You also might need to change parameter 2 to “Not Sent” but I’m not 100% sure from reading the manual exactly how this works.
Chis,
Here is a more complete dump:
56170-2020-09-07 17:58:40.492 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
56295-2020-09-07 17:58:40.494 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
56515-2020-09-07 17:58:40.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
56716-2020-09-07 17:58:40.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
56810:2020-09-07 17:58:40.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
56933:2020-09-07 17:58:40.496 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
57063:2020-09-07 17:58:40.496 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
57208:2020-09-07 17:58:40.496 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
57313:2020-09-07 17:58:40.496 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
57456:2020-09-07 17:58:40.497 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
57584:2020-09-07 17:58:40.497 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
57728:2020-09-07 17:58:40.497 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
57914:2020-09-07 17:58:40.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
58018:2020-09-07 17:58:40.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f2918e4.
58195-2020-09-07 17:58:40.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
58318-2020-09-07 17:58:40.498 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
58441-2020-09-07 17:58:40.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
58545-2020-09-07 17:58:40.499 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
58677-2020-09-07 17:58:40.567 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 20 01 FF 1E
58802-2020-09-07 17:58:40.569 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
59022-2020-09-07 17:58:40.569 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
59223-2020-09-07 17:58:40.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
59317:2020-09-07 17:58:40.570 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
59440:2020-09-07 17:58:40.570 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
59570:2020-09-07 17:58:40.571 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
59707:2020-09-07 17:58:40.571 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
59812:2020-09-07 17:58:40.571 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BASIC V1 BASIC_SET
59936:2020-09-07 17:58:40.571 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 49: Basic report, value = 255
60044:2020-09-07 17:58:40.572 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
60188:2020-09-07 17:58:40.572 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=255
60366:2020-09-07 17:58:40.572 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
60470:2020-09-07 17:58:40.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5b256695.
60648-2020-09-07 17:58:40.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
60771-2020-09-07 17:58:40.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
60894-2020-09-07 17:58:40.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
60998-2020-09-07 17:58:40.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
61130-2020-09-07 17:58:40.647 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 31 02 84 07 43
61252-2020-09-07 17:58:40.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 02 84 07
61469-2020-09-07 17:58:40.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 02 84 07
61667-2020-09-07 17:58:40.649 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
61761:2020-09-07 17:58:40.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
61884:2020-09-07 17:58:40.650 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
62014:2020-09-07 17:58:40.650 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Is awake with 0 messages in the queue
62134:2020-09-07 17:58:40.651 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Start sleep timer at 1000ms
62244:2020-09-07 17:58:40.651 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveNodeStatusEvent
62381:2020-09-07 17:58:40.654 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:alarm_tamper unlinked - polling stopped.
62541:2020-09-07 17:58:40.654 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:sensor_door unlinked - polling stopped.
62700:2020-09-07 17:58:40.655 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:battery-level unlinked - polling stopped.
62861:2020-09-07 17:58:40.661 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:alarm_tamper linked - polling started.
63019:2020-09-07 17:58:40.664 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:sensor_door linked - polling started.
63176:2020-09-07 17:58:40.675 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Channel zwave:device:161a521c:node49:battery-level linked - polling started.
63335:2020-09-07 17:58:40.676 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 49: Node Status event - Node is AWAKE
63451:2020-09-07 17:58:40.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
63555:2020-09-07 17:58:40.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3a1335fa.
63733-2020-09-07 17:58:40.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
63856-2020-09-07 17:58:40.676 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
63979-2020-09-07 17:58:40.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
64083-2020-09-07 17:58:40.677 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
64215-2020-09-07 17:58:40.767 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
64340-2020-09-07 17:58:40.769 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
64560-2020-09-07 17:58:40.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
64761-2020-09-07 17:58:40.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
64855:2020-09-07 17:58:40.772 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
64978:2020-09-07 17:58:40.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
65108:2020-09-07 17:58:40.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
65253:2020-09-07 17:58:40.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
65358:2020-09-07 17:58:40.773 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
65501:2020-09-07 17:58:40.773 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
65629:2020-09-07 17:58:40.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
65773:2020-09-07 17:58:40.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
65959:2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
66063:2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@5e10153e.
66241-2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
66364-2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
66487-2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
66591-2020-09-07 17:58:40.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
66723-2020-09-07 17:58:40.831 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 20 01 FF 1E
66848-2020-09-07 17:58:40.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
67068-2020-09-07 17:58:40.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
67269-2020-09-07 17:58:40.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
67363:2020-09-07 17:58:40.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
67486:2020-09-07 17:58:40.834 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
67616:2020-09-07 17:58:40.834 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
67753:2020-09-07 17:58:40.835 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
67858:2020-09-07 17:58:40.835 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BASIC V1 BASIC_SET
67982:2020-09-07 17:58:40.836 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 49: Basic report, value = 255
68090:2020-09-07 17:58:40.836 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
68234:2020-09-07 17:58:40.836 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=255
68412:2020-09-07 17:58:40.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
68516:2020-09-07 17:58:40.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@22cdb681.
68694-2020-09-07 17:58:40.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
68817-2020-09-07 17:58:40.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
68940-2020-09-07 17:58:40.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
69044-2020-09-07 17:58:40.837 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
69176-2020-09-07 17:58:40.912 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
69301-2020-09-07 17:58:40.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
69521-2020-09-07 17:58:40.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
69722-2020-09-07 17:58:40.914 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
69816:2020-09-07 17:58:40.915 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
69939:2020-09-07 17:58:40.915 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
70069:2020-09-07 17:58:40.915 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
70214:2020-09-07 17:58:40.916 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
70319:2020-09-07 17:58:40.916 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
70462:2020-09-07 17:58:40.916 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
70590:2020-09-07 17:58:40.916 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
70734:2020-09-07 17:58:40.917 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
70920:2020-09-07 17:58:40.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
71024:2020-09-07 17:58:40.917 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d2ebc7.
71201-2020-09-07 17:58:40.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
71324-2020-09-07 17:58:40.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
71447-2020-09-07 17:58:40.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
71551-2020-09-07 17:58:40.918 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
71683:2020-09-07 17:58:41.156 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: WakeupTimerTask 0 Messages waiting, state DONE
71812-2020-09-07 17:58:41.424 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Polling...
71905-2020-09-07 17:58:41.424 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 48: Polling zwave:device:161a521c:node48:switch_dimmer
72038-2020-09-07 17:58:41.425 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 48: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
72192-2020-09-07 17:58:41.425 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 48: Creating new message for command SWITCH_MULTILEVEL_GE
85967-2020-09-07 17:58:41.615 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 346: Advanced to WAIT_REQUEST
86074-2020-09-07 17:58:41.615 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 48: TID 346: Transaction not completed
86191-2020-09-07 17:58:41.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
86295-2020-09-07 17:58:41.616 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
86427:2020-09-07 17:58:41.656 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: WakeupTimerTask 0 Messages waiting, state DONE
86556:2020-09-07 17:58:41.657 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: No more messages, go back to sleep
86673:2020-09-07 17:58:41.657 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 49: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
86828:2020-09-07 17:58:41.657 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
86933:2020-09-07 17:58:41.657 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
87081:2020-09-07 17:58:41.657 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@61ac8a5f
87280:2020-09-07 17:58:41.658 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Bump transaction 347 priority from Immediate to Immediate
87420:2020-09-07 17:58:41.658 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Adding to device queue
87525:2020-09-07 17:58:41.659 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Added 347 to queue - size 2
87635-2020-09-07 17:58:41.659 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
87767-2020-09-07 17:58:41.723 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 0E 00 00 0B EE
87886-2020-09-07 17:58:41.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=14, payload=0E 00 00 0B
88084-2020-09-07 17:58:41.725 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=14, payload=0E 00 00 0B
92875-2020-09-07 17:58:41.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
92998-2020-09-07 17:58:41.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
93102-2020-09-07 17:58:41.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
93234-2020-09-07 17:58:41.820 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 31 02 84 08 25 0F 70
93368:2020-09-07 17:58:41.820 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 49: Sending REQUEST Message = 01 09 00 13 31 02 84 08 25 0F 70
93510-2020-09-07 17:58:41.822 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
93604-2020-09-07 17:58:41.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
93782-2020-09-07 17:58:41.823 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
93868-2020-09-07 17:58:41.823 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 347: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 1
95188-2020-09-07 17:58:41.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 347: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 15
95358-2020-09-07 17:58:41.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
95468-2020-09-07 17:58:41.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 347: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 15
95640-2020-09-07 17:58:41.835 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
95812:2020-09-07 17:58:41.835 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: sentData successfully placed on stack.
95933-2020-09-07 17:58:41.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 347: Advanced to WAIT_REQUEST
96040:2020-09-07 17:58:41.835 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 347: Transaction not completed
96157-2020-09-07 17:58:41.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
96261-2020-09-07 17:58:41.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
96393-2020-09-07 17:58:41.945 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 0F 00 00 0B EF
96512-2020-09-07 17:58:41.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=15, payload=0F 00 00 0B
97339-2020-09-07 17:58:41.948 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 347: (Callback 15)
97444-2020-09-07 17:58:41.948 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
97533-2020-09-07 17:58:41.949 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 347: callback 15
97641-2020-09-07 17:58:41.949 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=15, payload=0F 00 00 0B
97820:2020-09-07 17:58:41.949 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 49: SendData Request. CallBack ID = 15, Status = Transmission complete and ACK received(0)
97989:2020-09-07 17:58:41.949 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
98119-2020-09-07 17:58:41.950 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 347: Transaction COMPLETED
98223:2020-09-07 17:58:41.950 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Response processed after 127ms
98336:2020-09-07 17:58:41.950 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: TID 347: Transaction completed
98449:2020-09-07 17:58:41.950 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: notifyTransactionResponse TID:347 DONE
98570:2020-09-07 17:58:41.951 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
98717-2020-09-07 17:58:41.951 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 347: Transaction event listener: DONE: DONE ->
98842-2020-09-07 17:58:41.951 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
98946-2020-09-07 17:58:41.951 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
99078:2020-09-07 17:58:41.951 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Went to sleep COMPLETE
99183-2020-09-07 17:58:43.054 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 00 F3
99308-2020-09-07 17:58:43.056 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
99528-2020-09-07 17:58:43.056 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
99729-2020-09-07 17:58:43.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
99823:2020-09-07 17:58:43.057 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
99946:2020-09-07 17:58:43.057 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
100076:2020-09-07 17:58:43.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
100221:2020-09-07 17:58:43.058 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
100326:2020-09-07 17:58:43.058 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
100469:2020-09-07 17:58:43.059 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=0
100595:2020-09-07 17:58:43.059 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
100739:2020-09-07 17:58:43.060 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
100923:2020-09-07 17:58:43.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
101027:2020-09-07 17:58:43.060 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3a784506.
101205-2020-09-07 17:58:43.061 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
101328-2020-09-07 17:58:43.061 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
101451-2020-09-07 17:58:43.061 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
101555-2020-09-07 17:58:43.062 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
214180-2020-09-07 18:00:42.874 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
214305-2020-09-07 18:00:42.876 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
214525-2020-09-07 18:00:42.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
214726-2020-09-07 18:00:42.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
214820:2020-09-07 18:00:42.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
214943:2020-09-07 18:00:42.877 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
215073:2020-09-07 18:00:42.877 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
215218:2020-09-07 18:00:42.878 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
215323:2020-09-07 18:00:42.878 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
215466:2020-09-07 18:00:42.878 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
215594:2020-09-07 18:00:42.878 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
215738:2020-09-07 18:00:42.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
215924:2020-09-07 18:00:42.879 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
216028:2020-09-07 18:00:42.879 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@54f9ac2c.
216206-2020-09-07 18:00:42.880 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
216329-2020-09-07 18:00:42.880 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
216452-2020-09-07 18:00:42.880 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
216556-2020-09-07 18:00:42.880 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
216688-2020-09-07 18:00:42.950 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 20 01 FF 1E
216813-2020-09-07 18:00:42.952 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
217033-2020-09-07 18:00:42.952 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
217234-2020-09-07 18:00:42.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
217328:2020-09-07 18:00:42.953 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
217451:2020-09-07 18:00:42.953 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
217581:2020-09-07 18:00:42.954 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
217718:2020-09-07 18:00:42.954 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
217823:2020-09-07 18:00:42.954 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BASIC V1 BASIC_SET
217947:2020-09-07 18:00:42.955 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 49: Basic report, value = 255
218055:2020-09-07 18:00:42.955 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
218199:2020-09-07 18:00:42.955 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=255
218377:2020-09-07 18:00:42.956 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
218481:2020-09-07 18:00:42.956 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@58d89f59.
218659-2020-09-07 18:00:42.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
218782-2020-09-07 18:00:42.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
218905-2020-09-07 18:00:42.957 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
219009-2020-09-07 18:00:42.958 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false
222072-2020-09-07 18:00:44.635 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 00 F3
222197-2020-09-07 18:00:44.638 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
222417-2020-09-07 18:00:44.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
222618-2020-09-07 18:00:44.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
222712:2020-09-07 18:00:44.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
222835:2020-09-07 18:00:44.640 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
222965:2020-09-07 18:00:44.640 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
223110:2020-09-07 18:00:44.640 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
223215:2020-09-07 18:00:44.641 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
223358:2020-09-07 18:00:44.641 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=0
223484:2020-09-07 18:00:44.641 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
223628:2020-09-07 18:00:44.642 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
223812:2020-09-07 18:00:44.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
223916:2020-09-07 18:00:44.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@240e2d52.
224094-2020-09-07 18:00:44.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
224217-2020-09-07 18:00:44.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
224340-2020-09-07 18:00:44.643 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
224444-2020-09-07 18:00:44.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
224576-2020-09-07 18:00:45.526 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
224701-2020-09-07 18:00:45.528 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
224921-2020-09-07 18:00:45.528 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
225122-2020-09-07 18:00:45.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
225216:2020-09-07 18:00:45.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
225339:2020-09-07 18:00:45.529 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
225469:2020-09-07 18:00:45.529 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
225614:2020-09-07 18:00:45.530 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
225719:2020-09-07 18:00:45.530 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
225862:2020-09-07 18:00:45.530 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
225990:2020-09-07 18:00:45.531 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
226134:2020-09-07 18:00:45.531 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
226320:2020-09-07 18:00:45.531 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
226424:2020-09-07 18:00:45.531 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d8f7d33.
226602-2020-09-07 18:00:45.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
226725-2020-09-07 18:00:45.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
226848-2020-09-07 18:00:45.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
226952-2020-09-07 18:00:45.532 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
227084-2020-09-07 18:00:45.603 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 20 01 FF 1E
227209-2020-09-07 18:00:45.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
227429-2020-09-07 18:00:45.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 20 01 FF
227630-2020-09-07 18:00:45.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
227724:2020-09-07 18:00:45.606 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
227847:2020-09-07 18:00:45.606 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
227977:2020-09-07 18:00:45.606 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_BASIC, endpoint 0
228114:2020-09-07 18:00:45.607 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
228219:2020-09-07 18:00:45.607 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_BASIC V1 BASIC_SET
228343:2020-09-07 18:00:45.608 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 49: Basic report, value = 255
228451:2020-09-07 18:00:45.608 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
228595:2020-09-07 18:00:45.608 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BASIC, value=255
228773:2020-09-07 18:00:45.608 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
228877:2020-09-07 18:00:45.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@21310f8c.
229055-2020-09-07 18:00:45.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
229178-2020-09-07 18:00:45.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
229301-2020-09-07 18:00:45.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
229405-2020-09-07 18:00:45.610 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
230069-2020-09-07 18:00:46.998 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 00 F3
230194-2020-09-07 18:00:47.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
230414-2020-09-07 18:00:47.001 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 00
230615-2020-09-07 18:00:47.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
230709:2020-09-07 18:00:47.002 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
230832:2020-09-07 18:00:47.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
230962:2020-09-07 18:00:47.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
231107:2020-09-07 18:00:47.002 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
231212:2020-09-07 18:00:47.002 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
231355:2020-09-07 18:00:47.003 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=0
231481:2020-09-07 18:00:47.003 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
231625:2020-09-07 18:00:47.003 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
231809:2020-09-07 18:00:47.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
231913:2020-09-07 18:00:47.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2ae97569.
232091-2020-09-07 18:00:47.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
232214-2020-09-07 18:00:47.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
232337-2020-09-07 18:00:47.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
232441-2020-09-07 18:00:47.004 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
235501-2020-09-07 18:00:50.206 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 31 03 30 03 FF 0C
235626-2020-09-07 18:00:50.209 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
235846-2020-09-07 18:00:50.210 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=49, callback=0, payload=00 31 03 30 03 FF
236047-2020-09-07 18:00:50.210 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
236141:2020-09-07 18:00:50.210 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Application Command Request (ALIVE:DONE)
236264:2020-09-07 18:00:50.210 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: resetResendCount initComplete=true isDead=false
236394:2020-09-07 18:00:50.211 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
236539:2020-09-07 18:00:50.211 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 49: SECURITY not supported
236644:2020-09-07 18:00:50.211 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 49: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
236787:2020-09-07 18:00:50.211 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 49: Sensor Binary report, type=Unknown, value=255
236915:2020-09-07 18:00:50.212 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
237059:2020-09-07 18:00:50.212 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 49: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
237245:2020-09-07 18:00:50.212 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Commands processed 1.
237349:2020-09-07 18:00:50.212 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 49: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@39f825f6.
I have tried setting both groups to Send/Not Sent in the different combinations. No luck with that.
Here is the initialisation:
2020-09-26 14:42:03.889 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-09-26 14:42:03.890 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:alarm_tamper unlinked - polling stopped.
2020-09-26 14:42:03.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:sensor_door unlinked - polling stopped.
2020-09-26 14:42:03.891 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:battery-level unlinked - polling stopped.
2020-09-26 14:42:03.892 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:alarm_tamper linked - polling started.
2020-09-26 14:42:03.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:sensor_door linked - polling started.
2020-09-26 14:42:03.900 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Channel zwave:device:161a521c:node49:battery-level linked - polling started.
2020-09-26 14:42:03.903 [DEBUG] [ve.internal.protocol.ZWaveController] - **NODE 49** : Node Status event - Node is AWAKE
2020-09-26 14:42:03.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - **NODE 49** : Commands processed 1.
2020-09-26 14:42:03.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - **NODE 49** : Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@27f1b918.
2020-09-26 14:42:06.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - **NODE 49** : WakeupTimerTask 1 Messages waiting, state REQUEST_NIF
2020-09-26 14:42:06.693 [DEBUG] [nal.protocol.ZWaveTransactionManager] - **NODE 49** : Application Command Request (ALIVE:REQUEST_NIF)
2020-09-26 14:42:06.694 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - **NODE 49** : Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-09-26 14:42:06.694 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - **NODE 49** : SECURITY not supported
2020-09-26 14:42:06.695 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - **NODE 49** : Received COMMAND_CLASS_ALARM V0 NOTIFICATION_REPORT
2020-09-26 14:42:06.695 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - **NODE 49** : NOTIFICATION report - 0 = 255, event=3, status=255, plen=1
2020-09-26 14:42:06.696 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - **NODE 49** : Alarm Type = BURGLAR (0)
2020-09-26 14:42:06.696 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-09-26 14:42:06.697 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-09-26 14:42:06.697 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - **NODE 49** : Alarm converter processing NOTIFICATION
2020-09-26 14:42:06.698 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - **NODE 49** : Alarm converter NOTIFICATION event is 3, type OnOffType
2020-09-26 14:42:06.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - **NODE 49** : Updating channel state zwave:device:161a521c:node49:alarm_tamper to ON [OnOffType]
2020-09-26 14:42:06.699 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - **NODE 49** : Alarm converter processing NOTIFICATION
2020-09-26 14:42:06.700 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - **NODE 49** : Alarm converter NOTIFICATION event is 3, type OpenClosedType
2020-09-26 14:42:06.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - **NODE 49** : Commands processed 1.
If the channel/Thing definition changes between versions, your previously defined Thing won’t “fit” anymore.
Delete and rediscover the Thing - if you use the same UiD, all the old links will be restored. If individual channels have changed functionality, you may have to make some changes there.
What about parameter 2? Did you try this as well?
I have removed it from Openhab and reinitialised. I have also removed it from the Z-Wave network and re-added. No differences.
Thank you for the suggestion.
Yes, I have changed param 2 - “Sensor Binary Reports” to “Not Sent”. I have also tried setting param 1 to “Not Sent”
FWIW, I’m running build 2.5.7 build 171. My item is defined like this.
Contact GarageDoor_Tilt_Sensor "Garage Door Status [MAP(door.map):%s]" { channel="zwave:device:zstick:node24:sensor_door" }
Config Parameter 1 is set to Not Sent
Config Parameter 2 is set to Sent
The device is running firmware v 2.0.
In the event log, I’m getting open and closed events.
2020-09-22 12:07:05.101 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from CLOSED to OPEN
2020-09-22 12:07:59.757 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from OPEN to CLOSED
2020-09-22 16:16:00.234 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from CLOSED to OPEN
2020-09-22 16:18:09.477 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from OPEN to CLOSED
2020-09-22 18:01:59.359 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from CLOSED to OPEN
2020-09-22 21:11:38.187 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from OPEN to CLOSED
2020-09-22 21:13:33.964 [vent.ItemStateChangedEvent] - GarageDoor_Tilt_Sensor changed from CLOSED to OPEN
I upgraded to 2.5.10 build 237. I’m still getting open and close events.
Here’s the open event
2020-09-27 18:55:05.482 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 18 03 30 03 FF 25
2020-09-27 18:55:05.482 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 FF
2020-09-27 18:55:05.483 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 FF
2020-09-27 18:55:05.483 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-09-27 18:55:05.483 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:REQUEST_NIF)
2020-09-27 18:55:05.483 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-09-27 18:55:05.483 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-09-27 18:55:05.483 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-09-27 18:55:05.483 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=255
2020-09-27 18:55:05.483 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-09-27 18:55:05.483 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2020-09-27 18:55:05.483 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:zstick:node24:sensor_door to OPEN [OpenClosedType]
2020-09-27 18:55:05.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-09-27 18:55:05.484 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@4320173c.
And the close event
2020-09-27 18:56:00.945 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 18 03 30 03 00 DA
2020-09-27 18:56:00.945 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 00
2020-09-27 18:56:00.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=24, callback=0, payload=00 18 03 30 03 00
2020-09-27 18:56:00.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction TID 503: [WAIT_REQUEST] priority=NonceResponse, requiresResponse=true, callback: 88
2020-09-27 18:56:00.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:REQUEST_NIF)
2020-09-27 18:56:00.946 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-09-27 18:56:00.946 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-09-27 18:56:00.946 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-09-27 18:56:00.946 [DEBUG] [rotocol.commandclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=0
2020-09-27 18:56:00.946 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-09-27 18:56:00.946 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2020-09-27 18:56:00.946 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:zstick:node24:sensor_door to CLOSED [OpenClosedType]
2020-09-27 18:56:00.946 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-09-27 18:56:00.947 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1597741a.
I’m not sure why the database has changed, but it seems from Marks logs that it is also now incorrect, and it probably needs to be changed back. I will see if I can sort this out over the next day or two.
Ah, I see. The database has sensor_door associated with COMMAND_CLASS_ALARM_V1. But the device sends COMMAND_CLASS_SENSOR_BINARY.
Looks like the database change was very recent.
Yes, I don’t WHEN it happened, but I don’t know WHY :wink:
I can now verify the battery level does change, even if the other values do not.
So it makes a good z-wave enabled CR123A battery tester!
Just upgraded to 2.5.10, but no changes.
@chris Any luck with sorting out the changes in the Database?
Having the same issue. Is there any update/workaround?
What exactly is your issue, and what have your tried? What version of the bindings are you using and what is in the log?
Hi, Same issue as described by @tsmarks. Sensor worked in the past, but now “Door State [Deprecated]” does not get any updates.
Sensor sends COMMAND_CLASS_SENSOR_BINARY (values 0/255 when door is closed/open)
2020-12-29 15:00:22.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-12-29 15:00:22.033 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-12-29 15:00:22.033 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-12-29 15:00:22.033 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-12-29 15:00:22.033 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-12-29 15:00:22.033 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=255
2020-12-29 15:00:22.033 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-12-29 15:00:22.033 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=255
2020-12-29 15:00:22.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-12-29 15:00:22.033 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@10fde9f7.
2020-12-29 15:00:24.455 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-12-29 15:00:24.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-12-29 15:00:24.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_SENSOR_BINARY, endpoint 0
2020-12-29 15:00:24.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-12-29 15:00:24.455 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_SENSOR_BINARY V1 SENSOR_BINARY_REPORT
2020-12-29 15:00:24.455 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 24: Sensor Binary report, type=Unknown, value=0
2020-12-29 15:00:24.455 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveBinarySensorValueEvent
2020-12-29 15:00:24.455 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SENSOR_BINARY, value=0
2020-12-29 15:00:24.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-12-29 15:00:24.456 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@3d569239.
As per this topic and
it looks like openHAB expects COMMAND_CLASS_ALARM instead.
For reference this captures tampering (opening and closing the sensor cover):
2020-12-29 15:00:34.089 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-12-29 15:00:34.089 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-12-29 15:00:34.090 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Incoming command class COMMAND_CLASS_ALARM, endpoint 0
2020-12-29 15:00:34.090 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-12-29 15:00:34.090 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 24: Received COMMAND_CLASS_ALARM V2 NOTIFICATION_REPORT
2020-12-29 15:00:34.090 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 24: ALARM report - 0 = 255
2020-12-29 15:00:34.090 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 24: Alarm Type = BURGLAR (0)
2020-12-29 15:00:34.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2020-12-29 15:00:34.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_ALARM, value=255
2020-12-29 15:00:34.090 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 24: Alarm converter processing ALARM
2020-12-29 15:00:34.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:6d394c00:node24:alarm_tamper to ON [OnOffType]
2020-12-29 15:00:34.090 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Updating channel state zwave:device:6d394c00:node24:sensor_door to OPEN [OpenClosedType]
2020-12-29 15:00:34.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-12-29 15:00:34.090 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@218d0dec.
2020-12-29 15:00:41.234 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Application Command Request (ALIVE:DONE)
2020-12-29 15:00:41.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-12-29 15:00:41.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Is awake with 0 messages in the queue
2020-12-29 15:00:41.234 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Start sleep timer at 1000ms
2020-12-29 15:00:41.234 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-12-29 15:00:41.236 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 24: Node Status event - Node is AWAKE
2020-12-29 15:00:41.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Commands processed 1.
2020-12-29 15:00:41.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@31325ddb.
2020-12-29 15:00:41.734 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 0 Messages waiting, state DONE
2020-12-29 15:00:42.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: WakeupTimerTask 0 Messages waiting, state DONE
2020-12-29 15:00:42.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: No more messages, go back to sleep
2020-12-29 15:00:42.235 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 24: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2020-12-29 15:00:42.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: SECURITY not supported
2020-12-29 15:00:42.235 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2020-12-29 15:00:42.235 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@2074441a
2020-12-29 15:00:42.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Bump transaction 949 priority from Immediate to Immediate
2020-12-29 15:00:42.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Adding to device queue
2020-12-29 15:00:42.236 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Added 949 to queue - size 2
2020-12-29 15:00:42.237 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 24: Sending REQUEST Message = 01 09 00 13 18 02 84 08 25 87 D1
2020-12-29 15:00:42.245 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: sentData successfully placed on stack.
2020-12-29 15:00:42.245 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 949: Transaction not completed
2020-12-29 15:00:42.263 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 24: SendData Request. CallBack ID = 135, Status = Transmission complete and ACK received(0)
2020-12-29 15:00:42.263 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: resetResendCount initComplete=true isDead=false
2020-12-29 15:00:42.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: Response processed after 26ms
2020-12-29 15:00:42.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: TID 949: Transaction completed
2020-12-29 15:00:42.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 24: notifyTransactionResponse TID:949 DONE
2020-12-29 15:00:42.263 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 24: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-12-29 15:00:42.264 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 24: Went to sleep COMPLETE
