Ecovacs Vacuum Cleaners Binding [3.2.0;4.0.0)
Hi @maniac103 - definitely making progress! The bridge is connecting successfully now. I see this in the logs :
2022-03-01 07:41:32.087 [DEBUG] [s.internal.handler.EcovacsApiHandler] - Initializing Ecovacs account 'ecovacsapi'
2022-03-01 07:41:57.654 [DEBUG] [s.internal.handler.EcovacsApiHandler] - Ecovacs API initialized
2022-03-01 07:41:57.655 [DEBUG] [covery.EcovacsDeviceDiscoveryService] - Starting Ecovacs discovery scan
2022-03-01 07:41:58.018 [DEBUG] [covery.EcovacsDeviceDiscoveryService] - Ecovacs discovery found 1 devices
When I add the new device though (adding it from the Inbox in the UI), I see this :
2022-03-01 07:45:06.115 [DEBUG] [nternal.handler.EcovacsVacuumHandler] - E0001099017609490009: Initializing handler
2022-03-01 07:45:06.181 [TRACE] [.internal.api.impl.EcovacsXmppDevice] - E0001099017609490009: Connecting to XMPP
2022-03-01 07:45:11.872 [DEBUG] [nternal.handler.EcovacsVacuumHandler] - E0001099017609490009: Failed communicating to device, reconnecting
org.openhab.binding.ecovacs.internal.api.EcovacsApiException: org.jivesoftware.smack.SmackException: No supported and enabled SASL Mechanism provided by server. Server announced mechanisms: [PLAIN]. Registered SASL mechanisms with Smack: [SASL Mech: SCRAM-SHA-1-PLUS, Prio: 100, SASL Mech: SCRAM-SHA-1, Prio: 110, SASL Mech: X-OAUTH2, Prio: 410, SASL Mech: ANONYMOUS, Prio: 500]. Enabled SASL mechanisms for this connection: null. Blacklisted SASL mechanisms: [SCRAM-SHA-1-PLUS].
	at org.openhab.binding.ecovacs.internal.api.impl.EcovacsXmppDevice.connect(EcovacsXmppDevice.java:231) ~[?:?]
	at org.openhab.binding.ecovacs.internal.handler.EcovacsVacuumHandler.lambda$5(EcovacsVacuumHandler.java:480) ~[?:?]
	at org.openhab.binding.ecovacs.internal.handler.EcovacsVacuumHandler.doWithDevice(EcovacsVacuumHandler.java:671) ~[?:?]
	at org.openhab.binding.ecovacs.internal.handler.EcovacsVacuumHandler.connectToDevice(EcovacsVacuumHandler.java:479) ~[?:?]
	at org.openhab.binding.ecovacs.internal.handler.EcovacsVacuumHandler.lambda$0(EcovacsVacuumHandler.java:200) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
	at java.lang.Thread.run(Thread.java:834) [?:?]
Caused by: org.jivesoftware.smack.SmackException: No supported and enabled SASL Mechanism provided by server. Server announced mechanisms: [PLAIN]. Registered SASL mechanisms with Smack: [SASL Mech: SCRAM-SHA-1-PLUS, Prio: 100, SASL Mech: SCRAM-SHA-1, Prio: 110, SASL Mech: X-OAUTH2, Prio: 410, SASL Mech: ANONYMOUS, Prio: 500]. Enabled SASL mechanisms for this connection: null. Blacklisted SASL mechanisms: [SCRAM-SHA-1-PLUS].
	at org.jivesoftware.smack.SASLAuthentication.selectMechanism(SASLAuthentication.java:361) ~[?:?]
	at org.jivesoftware.smack.SASLAuthentication.authenticate(SASLAuthentication.java:192) ~[?:?]
	at org.jivesoftware.smack.tcp.XMPPTCPConnection.loginInternal(XMPPTCPConnection.java:402) ~[?:?]
	at org.jivesoftware.smack.AbstractXMPPConnection.login(AbstractXMPPConnection.java:528) ~[?:?]
	at org.jivesoftware.smack.AbstractXMPPConnection.login(AbstractXMPPConnection.java:485) ~[?:?]
	at org.openhab.binding.ecovacs.internal.api.impl.EcovacsXmppDevice.connect(EcovacsXmppDevice.java:221) ~[?:?]
I had a quick search this morning and found this - does it help?
