hello!
I would like to know a way to write in a json file (in Openhab/conf/html) some strings (contained in items read from the HABPannel) in my rules OpenHab.
my goal is to abtain a json file with credentials for a login. We need to:
part_1: Write in json “name, surname, ID” (during the registration)
part_2: Read from json the data to compare whith credentials created in part_1 (during the login)
i know it can be stupid but i’m a newbie in this world, be gently!
You can make use of jython rules that means you have language elements of python an can read/write files.
You could make use of the Exec binding or ExecuteCommandLine to run a script ( shell, python etc. ) to read/write a json file.
Perfect! i’ll try to do this , i would know if there were some OpenHab functiones to do this but the integrategration of this functionality by a Python code seems good.
Thank you
