My ekey LAN config tool is not t he home version - it’s the ekey net converter and the software was all the latest last year. The system itself is quite old though.
With regard to the UDP ports, what I’m still not clear about is how I find the port number used by my RPi running openHab. Where are people getting the number 51000 from?
Thanks for the advice. I was a little bit playing with the port numbers, i was actually using the same number on both sides, eg. 21000. My openhab is on address 192.168.0.150 and i’m listening on port 21000.
First i commented the delimiter line
# ip address of the eKey udp converter (optional)
ip=192.168.0.200
# port number for the UDP packets
port=21000
# mode can be RARE, MULTI or HOME depending on what your system supports - RARE is default
mode=RARE
# the delimiter is also defined on the eKey udp converter - use the eKey configuration
# software to determine which delimiter is used or to change it.
# Not defining this is the same as " "
# delimiter=_
changed the ekey naming, installed the NTP binding and added a test object in the items list, without success.
Number test "test" (deurstation) {udp="<[192.168.0.200:21000:'REGEX((.*))']"}
Number ekey_action "Letzte Aktion" <lock> (deurstation) {ekey="Action"}
Number ekey_userid "letzter Benutzer" <lock> (deurstation) {ekey="UserID"}
and enabled the udp port in my RPI as mentioned below.
So I played around a bit an openHab is now picking up the UDP datagrams. The Home format appears to be the same as the NET format so I set my LAN converters to NET format and the EKEY config to "HOME format.
I’m not sure, if the “test”-item listening on the same Port as your ekey works within OpenHab… Did you restart the OH2-server? In my tests, I had the feeling that just changing the config didn’t work at first, I had to restart the server.
Nevertheless, normally you don’t need anything apart configuring the ekey-binding (ekey.cfg) and adding items with the ekey-actions.
In the events.log I get only the “Userid”, not the “Action”?
2017-05-31 16:03:47.353 [ItemStateChangedEvent ] - ekey_doorUserid changed from 1 to 2
two Things:
do you use openHABian?
try getting the log-Level of the ekey-Binding to “TRACE”: log:set TRACE <<ID>>
for the latter:
go to the openhab-console
bundle-list
normally the last one should be the ekey-binding the left column is the ID of the bündle
That’s sadly exactly how far I did come while trying the non-RARE protocols. I tried a bunch of different delimiters, all of which didn’t work out - I opened an issue at github: [ekey] binding works with RARE, but not with MULTI or HOME · Issue #5014 · openhab/openhab1-addons · GitHub - unfortunately without further success until now.
I understand, you use an old Version of the CV LAN (the one with the RS232?) - I don’t know this one, but if it supports RARE, just try this protocol, at least it works for me.
just a shot in the dark: but try this deleting the ekey.config in /var/lib/openhab2/config/org/openhab (if you’re using openHAB in a LINUX-environment).
I did this, because sometimes the config wasn’t updated (not sure, if this issue is solved in the meantime, but worth a try!
After that, try restarting the openHAB-server, somehow I had the best results after restarts…
I’ve done that before. I just did it again and got the following when swiping a finger:
054 [ERROR] [ing.ekey.internal.EKeyPacketReceiver] - Error parsing packet
java.lang.IllegalArgumentException: It seems, that you passed an illegal packet!
at at.fhooe.mc.schlgtwt.parser.RarePacket.(RarePacket.java:56)[219:org.openhab.binding.ekey:1.10.0.201704230111]
at org.openhab.binding.ekey.internal.EKeyPacketReceiver.run(EKeyPacketReceiver.java:139)
oh, well. I’m confused also. those two where the last options I came up with in my installation… I’m afraid, I’m done so far.
Have you tried to put the binding into “TRACE”-loglevel? perhaps there’s some more Information?
Can I detect if someone uses unknow fingerprint? I want to know, if someone tries to enter the door by using his finger which is not in the database. Will this trigger an event?
Hi Tom,
do you use the openHABian image? if not, just give it a try - it’s really a fine piece of work! I use it and it works for all my needs - including ekey! http://docs.openhab.org/installation/openhabian.html
I have setup the eKey UDP converter in my eKey Multi environment. Everythings works fine so far except the terminalID.
My eKey configuration file
# IPv4 address of the eKey udp converter. A static IP address is recommended.
ip=192.168.0.99
# port as you configured during the UDP Converter configuration. For example, 51000
port=51000
# can be RARE, MULTI or HOME depending on what your system supports
mode=RARE
# the delimiter is also defined on the eKey UDP converter -
# use the eKey configuration software to determine which delimiter is used or to change it.
# Another option is `_` (underscore)
delimiter=_
My ekey.items file looks like this
Number eKey_UserID { ekey="userid" }
Number eKey_FingerID { ekey="fingerid" }
String eKey_TerminalID { ekey="terminalid" }
Number eKey_Action { ekey="action" }
When I check the openHab event Log I notice that the TerminalID is somehow incomplete or encrypted - the first 6 digits are missing. That’s also the reason why I have to use a string in the item file, before I have changed that from Number to String I always have had an conversion error in the logs.
2017-11-06 23:18:03.710 [ItemStateChangedEvent ] - eKey_UserID changed from NULL to 1
2017-11-06 23:18:03.711 [ItemStateChangedEvent ] - eKey_FingerID changed from NULL to 22
2017-11-06 23:18:03.711 [ItemStateChangedEvent ] - eKey_TerminalID changed from NULL to xxxxxx19150360
2017-11-06 23:18:03.711 [ItemStateChangedEvent ] - eKey_Action changed from NULL to 0
However, I have tried to replace the TerminalID with xxxxxx19150360 in order to get a proper result from the transformation, but that doesn’t work. Now, I’m confused how to solve this issue.
it should work like this then, if your ekey_terminal.map includes the xxxxxx as prefix. I don’t use it, as I do have only one terminal. I’ll have a look in my Setup the next days.
The binding gives you control over the ekey setup. Using the ekey UDP converter, you can use the binding for getting information from the binding (UDP Converter is only capable of getting information on users and fingers or non-authorized fingers).
But you can’t control the relays of your controlling unit (like EKEY multi SE REG 4 - 101163). The eKey controlling unit isn’t capable of receiving events from outside. So you have to think of an alternative on how to tell your door to open. What door opener do you use?
