Hi Marcel,
I figured, I do have configured my setup exactly like yours… ![]()
And it works:
ekey.cfg
# ip address of the eKey udp converter (optional)
ip=192.168.x.x
# port number for the UDP packets
port=21000
# mode can be RARE, MULTI or HOME depending on what your system supports - RARE is default
mode=RARE
# the delimiter is also defined on the eKey udp converter - use the eKey configuration
# software to determine which delimiter is used or to change it.
# Not defining this is the same as " "
#delimiter=_
ekey.items
/* eKey - Fingerprint */
DateTime ekey_doorActionTime "Letzte EKey-Aktion Zeit [%1$td %1$tb um %1$tR]]" <lock> (gEkey, EG_Windfang)
Number ekey_doorAction "EKey-Aktion [MAP(ekey_action.map):%s]" <lock> (gEkey, EG_Windfang) {ekey="Action"}
Number ekey_doorUserid "Benutzer [MAP(ekey_names.map):%s]" <lock> (gEkey, EG_Windfang) {ekey="UserID"}
Number ekey_doorFingerID "Benutzter Finger [MAP(ekey_finger.map):%s]" <lock> (gEkey, EG_Windfang) {ekey="FingerID"}
String ekey_doorTerminalID "Benutzes Terminal [MAP(ekey_terminal.map):%s]" (gEkey) {ekey="TerminalID"}
ekey_terminal.map
NULL=unbekannt
12345678901234=Haustür
xxxxxx78901234=Haustür
I don’t remember why I add this, and I don’t have the items logged in events.log, but I do get it transformed:
ekey.rules
rule "ekey Aktion"
Item ekey_doorUserid received update
if (ekey_doorUserid.state == -1) {
logInfo("ekey", "Es wurde kein Finger erkannt!")
} else {
var String name = transform("MAP","ekey_names.map",ekey_doorUserid.state.toString())
var String finger = transform("MAP","ekey_finger.map",ekey_doorFingerID.state.toString())
var String terminal = transform("MAP","ekey_terminal.map",ekey_doorTerminalID.state.toString())
var String vorgang = ""
if ((ekey_doorFingerID.state < 20) && (ekey_doorFingerID.state != 30)) {
// es war die linke Hand => zussperren
postUpdate(Nuki_doorLocked, ON)
vorgang = "zugesperrt"
if ((ekey_doorFingerID.state > 20) && (ekey_doorFingerID.state != 30)) {
// es war die rechte Hand => aufsperren
postUpdate(Nuki_doorLocked, OFF)
vorgang = "aufgesperrt"
postUpdate(ekey_doorActionTime, new DateTimeType())
var String text = name + " hat den" + finger + "Finger beim " + terminal + " Terminal aufgelegt und damit die Tür "+vorgang.toString
logInfo("ekey", "ekey-Aktion: "+text)
openhab.log:
2017-11-04 18:21:44.410 [INFO ] [.eclipse.smarthome.model.script.ekey] - ekey-Aktion: Andrea hat den rechten Zeige-Finger beim Haustür Terminal aufgelegt und damit die Tür aufgesperrt.
So just try putting both transforms in the map-file? ![]()
edit:
I set the binding into TRACE mode in the karaf console (log:set TRACE org.openhab.binding.ekey) and got the following in openhab.log:
2017-11-08 07:13:25.829 [DEBUG] [ab.binding.ekey.internal.EKeyBinding] - new packet arrived RarePacket [version=3, terminalid=5678901234, relayid=2, action=136, userid=0, fingerid=6(right index),
Now I’m completely confused, as the TerminalID doesn’t match my map-file…? ![]()
