I know that EKEY home and multi are supported with the EKEY 1.10.0 binding.
EKEY net uses RARE protocol too. It doesn’t work. Is there any chance that it should/could and I’ve got something amiss? Has anyone had any luck?
I tried it and got
2017-04-26 16:39:07.666 [ERROR] [ing.ekey.internal.EKeyPacketReceiver] - Error parsing packet
java.lang.IllegalArgumentException: It seems, that you passed an illegal packet!
at at.fhooe.mc.schlgtwt.parser.RarePacket.(RarePacket.java:56)[219:org.openhab.binding.ekey:1.10.0.201704230111]
at org.openhab.binding.ekey.internal.EKeyPacketReceiver.run(EKeyPacketReceiver.java:139)[219:org.openhab.binding.ekey:1.10.0.201704230111]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
My system is quite old and is using two CP WM3 units (with CV LAN add-ons) controlling four doors. I think the problem in my case my be more fundamental. Looking at the EKEY documentation, the RARE protocol is the same for all products (which makes sense), so it should work in principle. My admin is via EKEY.net in its current version.
I’m trying to look at the UDP datagrams to see if I can understand what’s going on.
