Hello!
I am using ekey home with openhab and it works fine! For the integration I used the manual on openhab.org (https://www.openhab.org/addons/bindings/ekey1/). For the communication between openhab an ekey i am using the ekey cv lan (Artikel-Nr.: 100460). Now the Problem: I need a second cv lan, because in my electrical system I have a ekey home (Artikel-Nr.: 101162) and a ekey multi (Artikel-Nr.: 101163). Is a second cv lan possible? In the binding configuration there is only a way to configurate a „ekey.cfg“ file.
Is there anybody with the same Problem?
Thanks, Micha1
