Dear community,
I have not succeeded in getting nor the Elelabs USB dongle or the shield ELR 023 to work in a stable manner with my Raspberry Pi 3. The problem seems to be that the coordinator setup does not survive a power reset reboot, it then displays a Error-communication . The reason (with the ELR 023 shield) seems to be, as per the log “Serial Error: Port [/dev/ttyAMA0] does not exist”
To isolate any other reasons, I have (for the ELR 023 shield), in the following sequence:
- Done a fully clean reinstallation of OpenHAB 3.3.0 on my Raspberry Pi 3, with nothing else configured
- Disabled the serial console
- Moved the bluetooth to miniUART
- Installed the OpenHAB Zigbee binding add-on
- Created an Ember Coordinator Thing - all working well and going online
- Rebooted the device through “sudo reboot” several times - the coordinator coming back online without problem
- Rebooting the device by repowering the device - the coordinator reports a communication error
- Subsequently rebooting the device through “sudo reboot” does NOT making the coordinator come back online anymore.
Worth to note is that /dev/ttyAMA0 does no longer show up as a serial port option when the error occurs, and OpenHAB has to be completely reinstalled to get it working again.
I have approached Elelabs customer support with several emails, but no answer, and they only have an outdated installation guide published. I would be most grateful for any support the community or @Elelabs can help me with.
The full chronological sequence of log data and full system spec can be found in the enclosed file.
Many thanks
Mats Rosenberg
Log clean install Elelabs.pdf (210.8 KB)
