Eltako FTKB - Received unknown RORG
I have a new Eltako FTKB, an enocean window/door contact.
Unfortunately the signal it sends, is not recognized.
2024-11-10 09:20:26.824 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG Unknown for  payload 31CF3F00000509D5815BAD05A363E90101FFFFFFFF5500 received
2024-11-10 09:20:26.824 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Received unknown RORG
2024-11-10 09:20:29.830 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG Unknown for  payload 31E5430000050A7B3A719505A363E90001FFFFFFFF5B00 received
2024-11-10 09:20:29.830 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Received unknown RORG
This occurs independently if there is a thing defined or not. The problem seems to be a level below.
Any idea how to get it run?
Please tell more about your setup.
Which bridge do you use?
Which Thing configuration?
I got two of these contacs and they work flawlessly.
I have already a couple of enocean devices. They all work without any problem. As gateway I have a USB300 USB-Gateway. There is also an additional repeater (Eltako FRP61) to bridge longer distances.
At the beginning I worked for a short period, I could learn the controller (for contact, but not for battery). But then it changed somehow and the signals sent are not recognized anymore.
My configuration is
Bridge enocean:bridge:FT1ZI6SV  "EnOcean Gateway" @ "Flur EG"
  path="/dev/serial/by-id/usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT1ZI6SV-if00-port0",
  enableSmack=true,
  espVersion="ESP3"
  Thing contact FensterBadOG                        "Fenstersensor Bad OG" @ "Bad OG"
    enoceanId="05A363E9",
    receivingEEPId="D5_00_01",
    receivingSIGEEP=true
As your Bridge seems to work with other devices, there should be no problem.
What about your Thing configuration?
As far as I know you don’t have to teach in these contacs into OH. You just add a Thing with the EnOcean ID from the contact and set your channels.
Edit: This config works for me:
UID: enocean:contact:4632083bac:6e2b6b40ec
label: Fensterkontakt 1
thingTypeUID: enocean:contact
configuration:
  receivingSIGEEP: true
  enoceanId: 052A779F
  receivingEEPId:
    - D5_00_01
bridgeUID: enocean:bridge:4632083bac
channels:
  - id: contact
    channelTypeUID: enocean:contact
    label: ""
    configuration: {}
  - id: lastReceived
    channelTypeUID: enocean:lastReceived
    label: ""
    configuration: {}
  - id: repeatCount
    channelTypeUID: enocean:repeatCount
    label: ""
    configuration: {}
  - id: rssi
    channelTypeUID: enocean:rssi
    label: ""
    configuration: {}
  - id: batteryLevel
    channelTypeUID: system:battery-level
    label: ""
    configuration: {}
Thanks for your assistance. Now I found out where the problem was. Accidentally I had enabled the encrypted communication. Since I disabled that, the contact works as it should. To get also the battery data, I still need to try.
Hi Beasty, did you also manage to get the battery level from the device?
With my config I just get a NULL value.
Number:Dimensionless    num_Bathroom_Window_Battery                     "Batterie-Zustand Sensor  [%d %%]"         <battery>          ["Measurement", "Energy"]    {channel="enocean:contact:FT1ZI6SV:FensterBadOG:batteryLevel", unit="%"}
No, sadly not.
Let me know, if you find a solution :wink:
It seems not to be supported, therefor I created a feature request:
