A simple webview widget that embeds a Google Maps view with traffic information between a starting point and an ending point.
You must get a Google Maps API Key. See Set up the Maps JavaScript API | Google for Developers for details. There may be a cost.
To customize this widget with additional properties see Embed a map | Maps Embed API | Google for Developers.
This widget is really simple. All it does is let you enter the properties that get directly passed to Google Maps in the URL. Only a fraction of the possible properties are currently supported so it should be easy to customize if you need something different.
My intent is to just publish an MVP and leave the tweaking to you. All you need to is to add the additional properties and their values to the arguments in the URL. If there is a particular feature a lot of people want I’ll consider adding it.
Changelog
Version 0.1
- initial release
Resources
uid: rlk_googlemap
tags: []
props:
parameters:
- description: See
https://developers.google.com/maps/documentation/javascript/get-api-key
to generate a key
label: Google Maps API Key
required: true
type: TEXT
- description: The starting point address or lat,lon
label: Origin
required: true
type: TEXT
- description: The ending point address or lat,lon
label: Destination
required: true
type: TEXT
- default: "12"
description: The initial map zoom level, between 0 (whole world) and 21
(individual buildings). Defaults to 12.
label: Initial Zoom
required: false
type: INTEGER
min: 0
max: 21
- default: ""
description: Title for the widget
label: Widget Title
required: false
type: TEXT
- default: "500"
description: Height in pixels to make the card (defaults to 500)
label: Card Height
required: false
type: TEXT
- default: ""
description: Text to put into the footer of the widget
label: Footer
required: false
parameterGroups: []
timestamp: Jan 8, 2025, 2:36:07 PM
component: oh-webframe-card
height: =props.height
src: ="https://www.google.com/maps/embed/v1/directions?key="+props.api+"&origin="+props.origin+"&destination="+props.destination+"&zoom="+props.zoom
title: =props.title
footer: =props.footer
