Hi everyone!
I have been using OpenHAB with embedded MQTT broker for almost 2 years now already, with no major issues until recently.
But now I have MQTT broker crashing and driving me nuts. I have read many posts with no solution for me yet.
And yes i did connect another tasmota device to MQTT two weeks ago, but issues apeared lately in last 4 days.
I still have OpenHAB 2.4.0 on windows 10 pc (64 bit).
CPU Celeron dual core (20 – 70 % load), 8gb ram (40% used)
Embedded MQTT broker 2.4
MQTT binding 2.4.
PC is Running only OpenHAB and Influx DB.
So, when I restart the win 10 computer OpenHAB loads fine and all MQTT devices connect without issues. Also devices remain connected for minimally 1 to 2 hours before reconnecting, nothing abnormal as MQTT devices all use Wi-Fi. Devices reconnect immediately after their reconnect timeout fires.
But sometimes for unknown reason the MQTT broker drops the connection, it is weird that it is likely to happen between 2 and 3 AM, but it happened also during the day, actually it happened 2 times today.
And the broker never starts again until I restart the OpenHAB / pc.
So, I did restore entire OpenHAB directory from one that I backed up in July 2020. From the latest version I only copied conf folder and things.json
to the restored OpenHAB folder. Then the embedded broker ran for 2 days straight and now it started crashing again?
I was also working on getting OH 2.5 with same configuration running on Linux peppermint but I had trouble migrating things config from paper UI and mosquito broker kept dropping the connection to some MQTT devices every few seconds. So that may mean something?
Back to the windows machine…
Is the issue with client IDs, probably not, as all devices communicate for hours just fine?
I have about 20 devices connected.
Is it the broker overloaded with too many messages per second? up to 10 messages per second, max message size 350 Bytes. Average message size 50 Bytes.
Is one MQTT device communicating badly and invoking errors?
It seems that OpenHAB kills embedded broker service as it may take to much time to process and in Karaf console in ttop it said timed waiting for MQTT broker when it stopped working.
I had a look at openhab.log
and I can’t see any exact reason why broker crashes.
2021-02-04 20:00:02.463 [INFO ] [ansport.mqtt.internal.ClientCallback] - MQTT connection to ‘127.0.0.1’ was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:181) [234:org.eclipse.paho.client.mqttv3:1.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133) ~[?:?]
… 7 more
2021-02-04 20:00:02.479 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline
… 7 more
2021-02-04 20:00:02.479 [WARN ] [.moquette.server.netty.NettyAcceptor] - An InterruptedException was caught while waiting for event loops to terminate…
2021-02-04 20:00:02.479 [WARN ] [.moquette.server.netty.NettyAcceptor] - Forcing shutdown of worker event loop…
2021-02-04 20:00:02.479 [WARN ] [.moquette.server.netty.NettyAcceptor] - Forcing shutdown of boss event loop…
2021-02-04 20:00:02.495 [ERROR] [io.moquette.server.Server ] - Moquette is not started, MQTT message interceptor cannot be removed. InterceptorId=collectmetrics
These logs still don’t tell why it crashed, maybe they tell how it crashed but that only the pro undertands.
But I can’t find any MQTT broker.log file as many posts write about where is it in Linux.
Any ideas why broker is crashing, and maybe possible solutions will be appreciated.
Thanks a lot in advance.
And thanks for your time.
Cheers.
~ Matej
