After latest snapshot installation and ‘forced’ shutdown of karaf, the next startup of openhab that greets me with an empty index page. It just shows “Welcome to openHAB 2.0” and no options for me to choose Paper UI or Classic UI.
Apparently, all the UI modules are not installed. What is the right sequent to install them manually? Thanks
2016-11-29 21:01:45.004 [INFO ] [ore.internal.i18n.LocaleProviderImpl] - Locale set to en_NZ
2016-11-29 21:01:54.906 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Weather.items’
2016-11-29 21:01:55.320 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'SystemInfo.items’
2016-11-29 21:01:55.469 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-11-29 21:01:55.564 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'NodeGeneral.items’
2016-11-29 21:01:56.523 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'NodeMQTT.items’
2016-11-29 21:01:56.881 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Groups.items’
2016-11-29 21:01:57.131 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'logging.persist’
2016-11-29 21:01:57.161 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist’
2016-11-29 21:02:01.686 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Bathroom.rules’
2016-11-29 21:02:02.185 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Power.rules’
2016-11-29 21:02:02.362 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'NodeAlarms.rules’
2016-11-29 21:02:02.900 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'GeneralSecurity.rules’
2016-11-29 21:02:06.115 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Mag50_Home.sitemap’
2016-11-29 21:02:11.697 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-11-29 21:02:12.419 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-11-29 21:02:13.337 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-11-29 21:02:14.292 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-29 21:02:20.873 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule ‘StartupBath’: org.eclipse.smarthome.core.library.types.DecimalType
2016-11-29 21:05:33.884 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2016-11-29 21:05:33.889 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn’t transform value in label because transformationService of type ‘MAP’ is unavailable
2016-11-29 21:05:33.894 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2016-11-29 21:05:33.897 [WARN ] [ui.internal.items.ItemUIRegistryImpl] - couldn’t transform value in label because transformationService of type ‘MAP’ is unavailable
However none of the bindings have been installed, and the paper UI doesn’t allow access to the extensions tab.
Running sudo apt-get update/Sudo apt-get upgrade for a second time overwrote the snapshot with the same snapshot (?) and fixed the issues (?)
i am not so lucky. Im getting all sorts of errors. FYI. Im using the latest offline snapshot:
2016-11-29 18:51:53.839 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.things’
2016-11-29 18:51:58.419 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2016-11-29 18:52:04.717 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-11-29 18:52:05.686 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist’
2016-11-29 18:52:17.133 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-package-standard’: Error restarting bundles
2016-11-29 18:52:26.184 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items’
2016-11-29 18:52:28.207 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error restarting bundles
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:848)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1089)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:985)[9:org.apache.karaf.features.core:4.0.4]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
Caused by: org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; osgi.identity=“org.eclipse.smarthome.io.rest.sse”; type=“osgi.bundle”; version:Version=“0.9.0.201611272028” [id=117] STARTED [STARTED]
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:329)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:389)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:412)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1199)[9:org.apache.karaf.features.core:4.0.4]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:840)[9:org.apache.karaf.features.core:4.0.4]
… 6 more
2016-11-29 23:55:02.869 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-11-29 23:56:52.492 [ERROR] [org.eclipse.smarthome.model.item ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.item
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)[org.osgi.core-6.0.0.jar:]
at com.eclipsesource.jaxrs.publisher.internal.Activator.openAllServiceTracker(Activator.java:91)[12:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at com.eclipsesource.jaxrs.publisher.internal.Activator.start(Activator.java:55)[12:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_101]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
Caused by: java.lang.IllegalStateException: Could not obtain lock
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainLock(AbstractComponentManager.java:198)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.obtainStateLock(AbstractComponentManager.java:246)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:763)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
… 33 more
2016-11-29 23:58:54.627 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items’
2016-11-29 23:59:05.837 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2016-11-29 23:59:28.520 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-11-29 23:59:29.909 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'myopenhab.persist’
2016-11-30 00:00:40.809 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.things’
2016-11-30 00:00:41.860 [INFO ] [core.karaf.internal.FeatureInstaller] - Installed ‘openhab-package-standard’
After a few rounds of reinstallations, all the UI bundles never got installed. Any ideas how to install them manually? I tried feature:install to install openhab-paperui, and installation was successful and active and I just can’t access it.
