I have been using an Echo outside for 3 years now, same Echo Dot v1, this entire time.
Here’s how I handle the different scenario’s:
- When leaving the house or at night, I set volumes to zero.
var EchoThing = getThingStatusInfo("amazonechocontrol:account:account1")
if ((EchoThing !== null) && (EchoThing.getStatus().toString() == 'ONLINE')) {
logInfo("ECHO","Alexa Outside Volume set to 0.")
createTimer(now().plusSeconds(5), [ | Echo_BackYard_Volume.sendCommand('0') ])
Thread::sleep(2000)
createTimer(now().plusSeconds(5), [ | Echo_BackYard_textToSpeechVolume.sendCommand('0') ])
Thread::sleep(2000)
Echo_BackYard_doNotDisturb.sendCommand(ON)
- Amazon likes to change volumes sometimes (not sure when/why):
rule "Echo BackYard Volume Changed by Amazon"
Item Echo_BackYard_Volume changed
var EchoThingBackYard = getThingStatusInfo("amazonechocontrol:echo:account1:echobackyard")
if ((systemStarted.state != ON && EchoThingBackYard !== null) && (Alexa_Status.state == 'ONLINE' && gInternet.state == ON && Echo_BackYard_Volume.state > 0 && Echo_BackYard_Volume.state <= 30)) {
logInfo("ECHO","Setting Echo_BackYard_Volume to 0 since its set under 30.")
logInfo("ECHO","Prior Echo_BackYard_Volume set to " + Echo_BackYard_Volume.state)
Thread::sleep(2000)
Thread::sleep(2000)
createTimer(now().plusSeconds(5), [ | Echo_BackYard_doNotDisturb.sendCommand(ON) ])
logInfo("ECHO","After Echo_BackYard_Volume set to " + Echo_BackYard_Volume.state)
- When the Echo device is used, it sends an email and takes a picture of who is in the back yard. If the house alarm system is ON or it’s past X hours at night, then I call an Alexa routine that kills whatever is asked of it.
Echo_BackYard_StartRoutine.sendCommand(‘kill use backyard echo’)
rule "Echo BackYard Last Command Heard Audit"
Item Echo_BackYard_LastVoiceCommand changed
if ((systemStarted.state != ON && EchoThingBackYard !== null) && (Alexa_Status.state == 'ONLINE' && gInternet.state == ON)) {
if (Echo_BackYard_LastVoiceCommand.state.toString() == 'amazon' && PatioDoor_Status.state != OPEN && gPart1Zone3Fault.state != ON && (currHour.state >= 22 || currHour.state <= 6)) {
Echo_BackYard_StartRoutine.sendCommand('kill use backyard echo')
Thread::sleep(1500)
logInfo("ECHO","Echo_BackYard_StartRoutine --> kill use backyard echo <-- executed.")
return;
if (gInternet.state == ON && (Echo_BackYard_LastVoiceCommand.state.toString() == 'amazon' || Echo_BackYard_LastVoiceCommand.state === null || Echo_BackYard_LastVoiceCommand.state == NULL)) { return; }
if (gInternet.state == ON && gPort25.state == ON && PatioDoor_Status.state != OPEN && gPart1Zone3Fault.state != ON) {
logInfo("ECHO","Echo_BackYard_LastVoiceCommand heard was --> " + Echo_BackYard_LastVoiceCommand.state.toString())
extract_date_time_formatted = now.format(java.time.format.DateTimeFormatter.ofPattern("MM_dd_yyyy_HH_mm"))
val string PatioDoorCam = "PatioDoor"+ extract_date_time_formatted +".jpg"
if (DVR.state == ON) {
executeCommandLine(Duration.ofSeconds(5), "wget", "-O", "/var/lib/openhab/pics/"+ PatioDoorCam, "http://user:pass@192.168.0.11:81/ISAPI/Streaming/channels/501/picture" )
var MailBinding = getThingStatusInfo("mail:smtp:4228b22a33")
if ((MailBinding !== null) && (MailBinding.getStatus().toString() == 'ONLINE' && gInternet.state == ON && gPort25.state == ON)) {
val mailActions = getActions("mail","mail:smtp:4228b22a33")
val String subjectemailEchoBackyard = "openHAB3 - Echo Backyard Used"
val String bodyemailEchoBackyard = "Echo_BackYard_LastVoiceCommand heard was --> " + Echo_BackYard_LastVoiceCommand.state.toString() + "."
val String attachment = "/var/lib/openhab/pics/" + PatioDoorCam
val String attachmentUrlListPushOver = attachment
val List<String> attachmentUrlList = newArrayList("file://" + attachment)
val String bodyemailEchoBackyardSMS = ''
mailActions.sendMail(JaygMail, subjectemailEchoBackyard, bodyemailEchoBackyard, attachmentUrlList)
logInfo("EMAIL",subjectemailEchoBackyard)
if (gInternet.state == ON) {
var String PushOverMessage = "Echo Used"
var String PushOverTitle = "Echo Backyard"
val pushOverActions = getActions("pushover","pushover:pushover-account:account")
pushOverActions.sendAttachmentMessage(PushOverMessage, PushOverTitle, attachmentUrlListPushOver, PushOverMIME)
logInfo("PUSHOVER",PushOverMessage)
if (gInternet.state == ON && gPort25.state == ON && UnifiPhones.state == OFF) {
logInfo("ECHO","Echo BackYard was used by someone other than our family members.")
mailActions.sendMail(JaySMS, subjectemailEchoBackyard, bodyemailEchoBackyardSMS)
Best, Jay
