It would be nice if there was a boolean configuration parameter for series with the semantics “initially hidden”. I have many charts in which I need the option of displaying additional series to analyze the situation. Often these are more series than the ones I want to see initially.
Of course, you can hide the series you don’t normally need with a mouse click, but that’s annoying.
If it were designed so that “true” means “initially hidden” and “false” or not set means “initially shown”, the extension would also be backwards compatible.
Do you mean something like this?
Thanks a lot. It works.
It also works if you just specify the hidden series (with “false”). Great!
