I am running latest OH2 and Raspbian.
I have already a Nodon “IN WALL MODULE - 2 CHANNELS” up and running fine.
Now I purchased additional ones and having issues adding them to my OH2 instance.
I added it through PaperUI as thing and configured the channels as items and added them to my sitemap. Just as I did for the first Nodon module.
Now I can push the button on the module to switch the attached device on and off. And I can see this event in the log (enabled debug mode for Enocean):
2020-06-26 09:38:15.110 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 058487F0 payload D2046180058487F00101FFFFFFFF5B00 received
2020-06-26 09:38:15.115 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload D2046180058487F001 for 058487F0 received
2020-06-26 09:38:15.158 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 058487F0 payload D2046080058487F00101FFFFFFFF5C00 received
2020-06-26 09:38:15.163 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload D2046080058487F001 for 058487F0 received
Same when switching on:
2020-06-26 09:39:26.498 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 058487F0 payload D20460E4058487F00101FFFFFFFF5C00 received
2020-06-26 09:39:26.502 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload D20460E4058487F001 for 058487F0 received
2020-06-26 09:39:26.562 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for 058487F0 payload D20461E4058487F00101FFFFFFFF5C00 received
2020-06-26 09:39:26.566 [DEBUG] [rnal.handler.EnOceanBaseThingHandler] - ESP Packet payload D20461E4058487F001 for 058487F0 received
Unfortunately this does not work when using BasicUI (nor PaperUI). I can click on the switch but nothing happens on the module- the device stays as is is (on or off). Here are the logs when I want to switch it off through BasicUI:
2020-06-26 09:40:54.225 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
2020-06-26 09:40:54.229 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type RADIO_ERP1, payload D2010000FFC148020001058487F0FF00
2020-06-26 09:40:54.251 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RESPONSE with code RET_OK payload 00 received
2020-06-26 09:40:54.282 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for FFC14802 payload D2010000FFC148028101058487F05B00 received
2020-06-26 09:40:57.202 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
2020-06-26 09:40:57.206 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type RADIO_ERP1, payload D2010100FFC148020001058487F0FF00
2020-06-26 09:40:57.224 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RESPONSE with code RET_OK payload 00 received
2020-06-26 09:40:57.258 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG VLD for FFC14802 payload D2010100FFC148028101058487F05B00 received
Anyone having an idea what is wrong here? It might be something totally simple but I do not see it…
Thanks a lot in advance!
/KNEBB
