Hello together,
since change from 3.2 → 3.3 there seems to be a bug in the support of the Eltako TF-FKE.
The EnOcean Transceiver throws an exception and there is no update of the item.
Thing is defined as (inside the corresponding enoecan bridge):
Thing contact st_EG_K_Fenster "st-EG-K-Fenster" @ "EG Kueche" [ enoceanId="FEED66BD", receivingEEPId="F6_10_00_EltakoFPE" ] //F6_10_00_EltakoFPE
Debug log:
2022-11-19 23:35:31.731 [DEBUG] [nternal.messages.ESP2PacketConverter] - Received ESP2 radio telegram: 0B05F0000000FEED66BD20
2022-11-19 23:35:31.733 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Converted to: RADIO_ERP1 with RORG RPS for FEED66BD
2022-11-19 23:35:31.734 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for FEED66BD payload F6F0FEED66BD20 received
2022-11-19 23:35:31.736 [ERROR] [ding.enocean.internal.eep.EEPFactory] - Cannot instantiate EEP F6-02-01: null
2022-11-19 23:35:31.737 [ERROR] [ernal.transceiver.EnOceanTransceiver] - Exception in informListeners
java.lang.IllegalArgumentException: java.lang.reflect.InvocationTargetException
at org.openhab.binding.enocean.internal.eep.EEPFactory.buildEEP(EEPFactory.java:75) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.handler.EnOceanBaseSensorHandler.packetReceived(EnOceanBaseSensorHandler.java:150) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.lambda$0(EnOceanTransceiver.java:309) ~[bundleFile:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.informListeners(EnOceanTransceiver.java:309) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanESP2Transceiver.processMessage(EnOceanESP2Transceiver.java:112) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver.receivePackets(EnOceanTransceiver.java:262) [bundleFile:?]
at org.openhab.binding.enocean.internal.transceiver.EnOceanTransceiver$1.run(EnOceanTransceiver.java:197) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.lang.reflect.InvocationTargetException
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.openhab.binding.enocean.internal.eep.EEPFactory.buildEEP(EEPFactory.java:67) ~[bundleFile:?]
... 13 more
Caused by: java.lang.IllegalArgumentException
at org.openhab.binding.enocean.internal.eep.EEP.setData(EEP.java:134) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.EEP.<init>(EEP.java:70) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.Base._RPSMessage.<init>(_RPSMessage.java:35) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.F6_02.F6_02.<init>(F6_02.java:52) ~[bundleFile:?]
at org.openhab.binding.enocean.internal.eep.F6_02.F6_02_01.<init>(F6_02_01.java:41) ~[bundleFile:?]
... 13 more
Is there anyone who could support?
Anyone using the TF-FKE sucessfully with the most updated version?
