I have two issus with the enocean binding:
- When I do
sendCommand(80)(jsscripting) a second time on the same rollershutter after it has reached the position from the firstsendCommand(80), the rollershutter moves all the way down.
First sendCommand(80) (moves correctly to ~80 %):
11:53:56.543 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
11:53:56.553 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Sending data, type RADIO_ERP1, payload A5000A0208000000120001FFFFFFFFFF00
11:53:56.559 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Unknown/unsupported ESP2Packet: 6B07000A02080000001200
11:53:56.976 [DEBUG] [internal.messages.ESP2PacketConverter] - Received ESP2 message telegram: 8B05020000000000001230
11:53:56.978 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Converted to: RADIO_ERP1 with RORG RPS for 00000012
11:53:56.979 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for 00000012 payload F6020000001230 received
11:53:56.981 [DEBUG] [ernal.handler.EnOceanBaseThingHandler] - ESP Packet payload F6020000001230 for 00000012 received
Reached position:
11:54:07.998 [DEBUG] [internal.messages.ESP2PacketConverter] - Received ESP2 message telegram: 8B070064020A0000001220
11:54:08.000 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Converted to: RADIO_ERP1 with RORG _4BS for 00000012
11:54:08.008 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG _4BS for 00000012 payload A50064020A0000001220 received
11:54:08.010 [DEBUG] [ernal.handler.EnOceanBaseThingHandler] - ESP Packet payload A50064020A0000001220 for 00000012 received
Second sendCommand(80) (no movement):
11:54:41.053 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
11:54:41.055 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Sending data, type RADIO_ERP1, payload A500000208000000120001FFFFFFFFFF00
Third sendCommand(80) (moves completely down):
11:55:02.265 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type RADIO_ERP1 without callback
11:55:02.266 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Sending data, type RADIO_ERP1, payload A500000208000000120001FFFFFFFFFF00
11:55:02.284 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Unknown/unsupported ESP2Packet: 6B07000002080000001200
11:55:03.037 [DEBUG] [internal.messages.ESP2PacketConverter] - Received ESP2 message telegram: 8B05020000000000001230
11:55:03.040 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Converted to: RADIO_ERP1 with RORG RPS for 00000012
11:55:03.042 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for 00000012 payload F6020000001230 received
11:55:03.043 [DEBUG] [ernal.handler.EnOceanBaseThingHandler] - ESP Packet payload F6020000001230 for 00000012 received
Reaches end:
11:55:33.324 [DEBUG] [internal.messages.ESP2PacketConverter] - Received ESP2 message telegram: 8B05500000000000001230
11:55:33.326 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - Converted to: RADIO_ERP1 with RORG RPS for 00000012
11:55:33.328 [DEBUG] [ternal.transceiver.EnOceanTransceiver] - RADIO_ERP1 with RORG RPS for 00000012 payload F6500000001230 received
11:55:33.330 [DEBUG] [ernal.handler.EnOceanBaseThingHandler] - ESP Packet payload F6500000001230 for 00000012 received
Thing and item:
Bridge enocean:bridge:fam14 "Eltako Bridge FAM14" [
path="/dev/ttyUSB0",
rs485BaseId="00000000",
rs485=true,
enableSmack=true,
espVersion="ESP2",
sendTeachOuts=false
Thing enocean:rollershutter:actuator_office_west "Rollladenaktor Büro Westen" [
enoceanId="00000012",
senderIdOffset=18,
sendingEEPId="A5_3F_7F_EltakoFSB",
receivingEEPId="F6_00_00","A5_3F_7F_EltakoFSB"
Channels: Type rollershutter:rollershutter [shutTime=13]
Rollershutter rollershutter_office_west "Rollladen Büro Westen" <rollershutter> (Office, rollershutter_west, rollershutter_west_og, rollershutter_og) ["Blinds"] {channel="enocean:rollershutter:actuator_office_west:rollershutter", autoupdate="false"}
- Some FSBs don’t react to the first command at all. They at least need a second or somtimes third command. I do have the same behaviour via the hardware switch though. Is there something like a deep sleep mode? This is the reason I’d have to send the same command multiple times, but it would lead to the problem I’ve described above on the shutters that moved correctly with the first command.
Any ideas?
