I am on openhab 3.
I use an Enocean binding and I have a configuration problem.
I would like to have some help on how to set up a rule.
I use an enocean pushbutton as a trigger.
In the choice of channels “pushbutton” works well but I can’t get “longpress” and “doublepress” to work.
In the event parameter I tried with pressed or released.
Here below the code of the rules:
triggers:
- id: “1”
configuration:
thingUID: enocean:pushButton:FT5MY15J:003A91C5
event: PRESSED
channelUID: enocean:pushButton:FT5MY15J:003A91C5:doublePress
type: core.ChannelEventTrigger
conditions: []
actions: - inputs: {}
configuration:
itemName: TZ30004js9lo5dTS0012_847127FFFEA48D41_2_Switch
command: ON
type: core.ItemCommandAction
Best regards
Thibault
