I am using Enshine Zigbee RGB+CCT light bulbs (Amazon.co.uk).
I’m not really sure what RGB+CCT means - they are capable of being set to RGB colours, but can also be set as white light bulbs with varying colour temperature and brightness.
I am more familiar with RGBWW (R+G+B+WW+CW) light bulbs which have 5 separate colour channels - red, green, blue, warm white, cold white.
In the Paper UI, these bulbs present two channels: Color of type Color, and Color Temperature of type Number.
I’d like to use lights as white lights of varying temperature and brightness most of the time, while retaining the option of using coloured lights.
I am using the Deconz binding to access these bulbs. In Phoscon, I have two options - either to select the Hue, Brightness and Saturation, OR, to select Brightness and Temperature. This works fine.
However, while I can see how I can set Hue, Saturation and Brightness from OpenHAB (and I have used this successfully in my Rules), I cannot see how to set Brightness + Temperature from OpenHAB.
Ideally, I’d like to be able to program R, G, B, WW, CW channels independently, but I can’t see how to do this at all, either from Phoscon or from OpenHAB.
Alternatively, does anyone know of other RGBWW Zigbee light bulbs which are supported in OpenHAB where I can control R, G, B, WW, CW channels independently from OpenHAB rules?
Thank you.
