Ephemeris issues with custom xml
Hi all, and maybe directly @rlkoshak :wink:
since hours im trying to configure Ephemeris. I configured it via the Ui to Germany, Baden-Württemberg, and weekends to SATURDAY, SUNDAY and the city to wn.
With the default holidays, its working fine now, but i wanted to add a custom holiday file. Therefore i downloaded the one from Actions | openHAB
and placed it here: /etc/openhab/services/Holidays_de.xml
The file is owned by user openhab and is set to ‘rw’.
In my Rules DSL file automation.rules i have the following:
rule "Ephemeris test"
    Time cron "0 * * * * ? *"
        logInfo("Ephemeris", "Ephemeris: " + Ephemeris.getNextBankHoliday('/etc/openhab/services/Holidays_de.xml'))
but the log then just mentions:
2024-02-19 18:10:00.981 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'automation-1' failed: Cannot instantiate configuration from URL 'file:/etc/openhab/services/Holidays_de.xml'. in automation
Has anybody any idea, how to get that to work?
And directly the next two question:
  1. Is it possible to give a custom name, e.g.: schulferien? So this would allow to have multiple lists to distinguish between.
  2. How would one define a time range in the xml file, e.g. 25.03.2024 - 05.05.2024 ? Is this possible or do i have to define each and every day? By reading jollday spec I absolutely do not understand how to do so.
  3. How would one specify a lookup to a CALDAV path?
Thanks in advance for guiding me here :+1:
I did a test with a DSL rule:
rule "ephemeris message"
when Time cron "0/10 * * * * ?"
logInfo("Rules", Ephemeris.getNextBankHoliday("/etc/openhab/services/MyEntry_de.xml"))
With MyEntry_de.xml contains:
<?xml version="1.0" encoding="UTF-8"?>
<tns:Configuration hierarchy="de" description="Germany" xmlns:tns="http://www.example.org/Holiday"
                   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                   xsi:schemaLocation="http://www.example.org/Holiday /Holiday.xsd">
    <tns:Holidays>
        <tns:Fixed month="DECEMBER" day="26" descriptionPropertiesKey="MY_SECOND_CHRISTMAS_DAY"/>
        <tns:Fixed month="DECEMBER" day="28" descriptionPropertiesKey="XXXXXXXXX"/>
    </tns:Holidays>
</tns:Configuration>
and the output in openhab.log file then is
2024-02-19 22:41:20.811 [INFO ] [org.openhab.core.model.script.Rules ] - MY_SECOND_CHRISTMAS_DAY
2024-02-19 22:41:30.811 [INFO ] [org.openhab.core.model.script.Rules ] - MY_SECOND_CHRISTMAS_DAY
2024-02-19 22:41:40.811 [INFO ] [org.openhab.core.model.script.Rules ] - MY_SECOND_CHRISTMAS_DAY
2024-02-19 22:41:50.812 [INFO ] [org.openhab.core.model.script.Rules ] - MY_SECOND_CHRISTMAS_DAY
2024-02-19 22:42:00.811 [INFO ] [org.openhab.core.model.script.Rules ] - MY_SECOND_CHRISTMAS_DAY
I think this is answered as I used a customimzed name ..?
I’m using my own file for birthdays and placed it here “/openhab/conf/services/birthdays.xml” with OpenHAB 4.1.1 under Docker.
In JS the code to read the
            nextBithday = actions.Ephemeris.getNextBankHoliday('/openhab/conf/services/birthdays.xml');
Hi @Wolfgang_S ,
great, thanks for your reply. I now just simply copied exactly what you have specified, and its now perfectly working and this is a superb starting point for me. Thanks also for question no 1 (also to @uk59821 ).
Has anybody hints to Questions 2 and 3?
Thanks in advance
On jollyday related github issues there is also a question about vacation .. it is unanswered.
I did not try it but it may be possible to do something like
               <tns:FixedWeekdayBetweenFixed weekday="MONDAY" descriptionPropertiesKey="VACATION">
                        <tns:from month="JANUARY" day="19" />
                        <tns:to month="JANUARY" day="25" />
                </tns:FixedWeekdayBetweenFixed>
               <tns:FixedWeekdayBetweenFixed weekday="TUESDAY" descriptionPropertiesKey="VACATION">
               <tns:FixedWeekdayBetweenFixed weekday="WEDNESDAY" descriptionPropertiesKey="VACATION">
               <tns:FixedWeekdayBetweenFixed weekday="THURSDAY" descriptionPropertiesKey="VACATION">
               <tns:FixedWeekdayBetweenFixed weekday="FRIDAY" descriptionPropertiesKey="VACATION">
FixedWeekdayBetweenFixed is taken from the examples. It is just copied and manipulated with regard to show every weekday ( MONDAY .. FRIDAY ).
I think 1 and 2 are answered above. 3 is not possible through Ephemeris as far as I know nor do I know of binding that supports caldav (only iCalendar).
You might be able to make something work through the HTTP binding and actions but it’s probably going to be a lot of work.
