Ephemeris with custom.xml file
I tried to set up a Custom Jollyday File named “custom.xml”. This works like a charm unless the file was modified. An edited event won’t be shown in the Main UI. Instead the old entry is still shown. The edited entry is up-to-date when the openhab system has been restarted.
Is there a way to force a “re-read” of the custom.xml without rebooting the container?
My config:
OpenHAB 4.2.3 in a docker environment installed on a Raspberry Pi 4
Cheers
Elch2000
