I started to use the Epson Projector Binding and getting warnings and errors.
- Raspberry Pi v2
- openHAB 1.8.0 and 1.8.1
- Epson TW700
- Raspberry serial port connection ttyAMA0
Function is OK. I can switch on/off, mute on/off and select the source.
Also source change is written back and also power on/off updates are received.
Mute is not update from projector towards openHAB.
Items:
/* Control */
Switch epsonPower “Beamer” { epsonprojector=“beamer:Power:60000” }
Switch epsonMute “Mute” <beamer_mute> { epsonprojector=“beamer:Mute:ON,60000” }
Number epsonDirectSource “Quelle” { epsonprojector=“beamer:DirectSource:ON,60000”}
Log:
Seen while projector is on
2016-02-10 17:47:11.157 [WARN ] [.o.b.e.i.EpsonProjectorBinding] - Couldn’t execute command ‘Mute’, org.openhab.binding.epsonprojector.internal.EpsonProjectorException: Illegal response
2016-02-10 17:47:11.158 [ERROR] [.o.b.e.i.EpsonProjectorBinding] - No response received from command ‘Mute’
It helps to set the time value to a huge number to avoid polling.
Seen in start up or power down phase of the projector
2016-02-10 17:45:08.754 [WARN ] [.o.b.e.i.EpsonProjectorBinding] - Couldn’t execute command ‘Power’, org.openhab.binding.epsonprojector.internal.EpsonProjectorException: No response received
2016-02-10 17:45:10.786 [ERROR] [.o.b.e.i.EpsonProjectorBinding] - Couldn’t execute command ‘Power’, org.openhab.binding.epsonprojector.internal.EpsonProjectorException: Error response received
Errors and warnings can also be seen if the projector is completely powered off.
Does anyone know how to deal with this binding to get rid off the warnings and errors?
