i use 2 scripts to turn on and off my govee immersion tv light strip.
rule "govee_on"
Item tv_lights received command ON
or
Item HarmonyHubLivingRoom_ changed to 'SHIELD TV'
or
Item HarmonyHubLivingRoom_ changed to 'Watch Tv'
executeCommandLine("/etc/openhab/scripts/govee_on.sh")
rule "govee_off"
Item tv_lights received command OFF
or
Item HarmonyHubLivingRoom_ changed to 'PowerOff'
or
Item HarmonyHubLivingRoom_ changed to 'Watch a Movie'
executeCommandLine("/etc/openhab/scripts/govee_off.sh")
for 6-7 months this worked like a charm.Today i got this log error
2021-12-12 20:25:52.591 [WARN ] [rg.openhab.core.io.net.exec.ExecUtil] - Error occurred when executing commandLine '[/etc/openhab/scripts/govee_on.sh]'
java.io.IOException: Cannot run program "/etc/openhab/scripts/govee_on.sh": error=13, Permission denied
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1128) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1071) ~[?:?]
at org.openhab.core.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:59) ~[?:?]
at org.openhab.core.model.script.actions.Exec.executeCommandLine(Exec.java:40) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1192) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1167) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1153) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1098) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1008) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:971) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:247) ~[?:?]
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:131) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1183) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:991) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:90) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.io.IOException: error=13, Permission denied
at java.lang.ProcessImpl.forkAndExec(Native Method) ~[?:?]
at java.lang.ProcessImpl.<init>(ProcessImpl.java:340) ~[?:?]
at java.lang.ProcessImpl.start(ProcessImpl.java:271) ~[?:?]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1107) ~[?:?]
... 36 more
my files permissions
openhabian@openhabian:/etc/openhab/scripts $ ls -l
total 16
-rw-rw-r-- 1 openhab openhab 307 Jun 18 22:38 govee_off.sh
-rw-rw-r-- 1 openhab openhab 306 Jun 18 22:18 govee_on.sh
-rw-rw-r-- 1 openhab openhab 236 May 28 2018 readme.txt
drwxrwxr-x 5 openhab openhab 4096 Dec 11 11:35 thinq2-python
usually running “fix permissions” from openhabian-config solves this kind of problems but not now…
Any help from linux experts?
