I have a problem with showing an item string inside a frame widget. It is independent which item string I used. Every time there is an error 404 inside the widget. The notification shows HTTP ERROR 404 Problem accessing /habpanel/FRITZ!Box%207430. Reason: Not Found
Powered by Jetty://
Can somebody explain me the problem? I have no idea. The address shows the right value of the string: Fritz!Box 7430.
Thank you for your help.
Greetings johannes
