Hello. i want to configurate my own openhabcloud. It works for 2.5. But I want to configurate for OH3
I get error 502 bad gateway.
nginx.txt (6.2 KB)
Did you upgrade the openhabcloud stuff as for 3.X there have been changes in the code ?
Yes, I have last version. And also I instaled new nginx configs..
I do not see two of the entries that are being used by the nginx.conf that is provided in the set of templates provided by openhabian-config: openhabian/includes/nginx.conf at main · openhab/openhabian · GitHub ( they are marked with #AUTH ). That template is used by the openhabian-config scripts to setup a nginx.conf file.
this config for reverse proxy? But I use openhabcloud server..
