I am setting up openHAB for a small company network. I got OH to work on the Pi and can connect to it with my laptop using the static IP of the Pi, and I’m able to use the nano editor in ssh. Attached is the screenshot of it.
Seems you already have an active connection to the server with different credentials. You have to logout from Windows desktop to cancel the connection.
Try to access these folders from other PC (preferably with other OS). If this will not help, connect your PC to RPi directly via Ethernet cable and try it again.
You don’t need to get internet in such case. You should check access to Openhabian shared folder directly (witout connecting to local network). If you can, you will know that there are some security issues in your local network.
I’m not sure about that. In fact, even if accessing only the UNC path, Windows will cache that access with user credentials and will prevent logins with other user credentials until you are logged off an on again to the windows session.
The credentials are still not working for the shares.
Either the access to the share has to be reconfigured or there is another user for SMB access.
Can anyone tell me how I can do it?
