Hi together
Today, I made a Update of my Openhabian to Version 2.5.7-1. After that I made updates of my Shelly’s. After the updates I received a lot of errors like that:
2020-08-13 16:25:19.422 [WARN ] [.californium.core.network.UdpMatcher] - error receiving response ACK-2.05 MID=28539, Token=, OptionSet={“Unknown (3332)”:0x534853572d31234238423945392332}, "{“blk”:[{“I”:1,“D”:“rela”… 867 bytes for Exchange[L26304, complete]
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected a string but was BEGIN_ARRAY at line 1 column 319 path $.sen[3].R
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:224) ~[?:?]
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:41) ~[?:?]
at com.google.gson.internal.bind.CollectionTypeAdapterFactory$Adapter.read(CollectionTypeAdapterFactory.java:82) ~[?:?]
at com.google.gson.internal.bind.CollectionTypeAdapterFactory$Adapter.read(CollectionTypeAdapterFactory.java:61) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:129) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:220) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:888) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:853) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:802) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:774) ~[?:?]
at org.openhab.binding.shelly.internal.coap.ShellyCoapHandler.handleDeviceDescription(ShellyCoapHandler.java:252) ~[?:?]
at org.openhab.binding.shelly.internal.coap.ShellyCoapHandler.processResponse(ShellyCoapHandler.java:216) ~[?:?]
at org.openhab.binding.shelly.internal.coap.ShellyCoapHandler$1.onResponse(ShellyCoapHandler.java:884) ~[?:?]
at org.eclipse.californium.core.coap.Request.setResponse(Request.java:711) ~[bundleFile:?]
at org.eclipse.californium.core.network.EndpointManager$ClientMessageDeliverer.deliverResponse(EndpointManager.java:272) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.BaseCoapStack$StackTopAdapter.receiveResponse(BaseCoapStack.java:210) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.AbstractLayer.receiveResponse(AbstractLayer.java:89) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.ExchangeCleanupLayer.receiveResponse(ExchangeCleanupLayer.java:93) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.ObserveLayer.receiveResponse(ObserveLayer.java:150) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.BlockwiseLayer.receiveResponse(BlockwiseLayer.java:676) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.ReliabilityLayer.receiveResponse(ReliabilityLayer.java:305) ~[bundleFile:?]
at org.eclipse.californium.core.network.stack.BaseCoapStack.receiveResponse(BaseCoapStack.java:139) ~[bundleFile:?]
at org.eclipse.californium.core.network.CoapEndpoint$1.receiveResponse(CoapEndpoint.java:277) ~[bundleFile:?]
at org.eclipse.californium.core.network.UdpMatcher$4.run(UdpMatcher.java:399) [bundleFile:?]
at org.eclipse.californium.elements.util.SerialExecutor$1.run(SerialExecutor.java:276) [bundleFile:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_252]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
Caused by: java.lang.IllegalStateException: Expected a string but was BEGIN_ARRAY at line 1 column 319 path $.sen[3].R
at com.google.gson.stream.JsonReader.nextString(JsonReader.java:825) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$16.read(TypeAdapters.java:401) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$16.read(TypeAdapters.java:389) ~[?:?]
… 32 more
This error occurs once per second and I can’f find the reason. I restarted openhab and the error is the same. What I found out is, that a Shelly H&T no more work. I made a restore of the version of the previous firmware but the error is still the same.
Could everyone help me about that
Thx in advance.
