Hey all,
I just installed a new Schlage lock that is zwave compatible. I’ve got it paired up and can lock/unlock via openhab. There is also an alarm_raw channel that provides a JSON with some extra info like when the lock is operated manually or via keypad informs you via this item.
Examples of this output are as follows:
{"notification":"ACCESS_CONTROL__MANUAL_LOCK", "level":"1" "type":"ACCESS_CONTROL","event":"1","status":"255"}
{"notification":"ACCESS_CONTROL__KEYPAD_LOCK", "level":"0" "type":"ACCESS_CONTROL","event":"5","status":"255"}
{"notification":"ACCESS_CONTROL__MANUAL_UNLOCK", "level":"1" "type":"ACCESS_CONTROL","event":"2","status":"255"}
{"notification":"ACCESS_CONTROL__KEYPAD_UNLOCK", "code":"3", "level":"3", "type":"ACCESS_CONTROL","event":"6","status":"255"}
The “event” item in this JSON is unique to the event happening so I can determine if the lock was manually or keypad operated to lock or unlock.
So, I’m trying to use JSONPATH transformation in a rule to get this bit out to do stuff with and I’m having issues:
From my .items file:
String sidedoorlockAlarm "Side Door Lock Alarm [%s]" <soundvolume-0> {channel="zwave:device:ddbf0ba4:node22:alarm_raw"}
String sidedoorlockStatus "Side Door Lock [%s]"
Then my rule:
rule "sidedoor-lock"
Item sidedoorlock changed or
Item sidedoorlockAlarm changed
sidedoorlockStatus = transform("JSONPATH", "$.event", sidedoorlockAlarm.state.toString)
I get the following error when I make the rule run:
2019-11-01 15:21:25.345 [vent.ItemStateChangedEvent] - sidedoorlockAlarm changed from {"notification":"ACCESS_CONTROL__MANUAL_UNLOCK","level":"1","type":"ACCESS_CONTROL","event":"2","status":"255"} to {"notification":"ACCESS_CONTROL__MANUAL_LOCK","level":"1","type":"ACCESS_CONTROL","event":"1","status":"255"}
2019-11-01 15:21:25.372 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'sidedoor-lock': An error occurred during the script execution: Cannot assign a value in null context.
Does anyone have any idea whats going on here?
