hello,
I’m new in the whole openhab and smart home.
i have this problem that i cant find on the internet why it happens.
i get this error in the openhablog
2019-06-02 20:43:12.049 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.054 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.058 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.065 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.069 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.073 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.077 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.081 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.084 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.087 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.089 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'DEMOSW' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.091 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.093 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'kleinekamer' for widget org.eclipse.smarthome.model.sitemap.Switch
2019-06-02 20:43:12.095 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'kleinekamer' for widget org.eclipse.smarthome.model.sitemap.Switch
this is my .items file
<//This is the Items File
//Demo items
Switch DEMOSW "Demo Switch"
//Sonoff Basic
Switch Youri "Normaal licht" <poweroutlet> [ "Switchable" ] {mqtt=">[broker:cmnd/sonoffswitch1/POWER:command:*:default],<[broker:stat/sonoffswitch1/POWER:state:default]", autoupdate="false"}
Switch kleinekamer "Normaal licht" <poweroutlet> [ "Switchable" ] {mqtt=">[broker:cmnd/sonoffswitch2/power:command:*:default],<[broker:stat/sonoffswitch2/power:state:default]", autoupdate="false"}
and this is my sitemap
sitemap home label="Youri"
Frame label="Demo"
Switch item=DEMOSW
Frame label="Information"
Switch item=DEMOSW
Frame label="Security"
Switch item=DEMOSW
Frame label="Room"
Switch item=DEMOSW
Frame label="Kleinemer"
Switch item=kleinekamer
Frame label="Youri Bedroom"
Switch item=Youri
Frame label="Living Room"
Switch item=DEMOSW
Frame label="Garage"
Switch item=DEMOSW
Frame label="Outside"
Switch item=DEMOSW
can anyone help me figure out why this is happening.
all was working until i copied a switch and edited it to be a seperate switch and then this happend.
i see it wont reconise the item but why?
