Error connecting to the openHAB Cloud
I have the following error on one of my instances of openHAB:
Error connecting to the openHAB Cloud instance: pool destroyed. Reconnecting after 60000 ms.
Raspberry Pi 3 - openHAB 4.3.4
On my instance running latest 5.0. Millestone I have no problems connecting to the cloud
Is that a problem on my side or on the cloud server?
I have the same error on OpenHAB 4.3.2
I noticed it today. Yesterday was working good.
Is it the same for you?
Yes, I check the service every 15 minutes and the failure is since midnight (MESZ).
Same for me on 4.2.1. Reboot not helped,
status.openhab.org says the Cloud server is up.
I don’t know what the status was last week, but I also got the "Internal server error"
information when logging into myopenhab.org.
As far as I understand from @digitaldan, the problem wasn’t entirely clear.
Still not working for me.
Not working for me either
Yes, i also had the same problem that day.
I hope @digitaldan finds the problem
Same problem right now, cannot connect using Cloud connector.
Also getting random “Internal Server Error” when login on myopenhab.org .
Rebooted and still says Offline
Looking now, not sure what the issue is
Reconnected! Thx!
So one of our servers exhausted is DB pool, but continued to take traffic, so if you were unlucky enough to be pinned to that server by our load balancer, it was failing. I look into failing the server completely when that happens, my guess is this was the cause last time we had an issue as well.
Its also strange that both issues happened within 12 hours of our hosting provider doing emergency maintenance on the hardware serving that node. I’m not sure if they reboot it (which would be the safe choice) , or try doing a live migration (which might be causing issues), but something seems to get it into a really bad state.
