Hi
I just managed to upgrade the modbus binding from ver.1 to ver.2.
I use the modbus binding to read/control Villavent/Systemair VR 400 DC.
I do get information and I can change parameter so everything works fine.
The only this is when I check the logs I see error/warning described below.
It’s something that I can do to get rid of the error?
16:43:43.639 [WARN ] [ort.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusReadRequestBlueprint@1774abc[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=100,length=1,maxTries=3]). Will try again soon. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: IOException CRC Error in received frame: 0 bytes: [operation ID cb0f871c-e6cd-48a8-b2d5-e6ab2b5305f8]
16:43:44.624 [WARN ] [ort.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusReadRequestBlueprint@1774abc[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=100,length=1,maxTries=3]). Will try again soon. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: IOException CRC Error in received frame: 5 bytes: 00 03 02 00 02 [operation ID cb0f871c-e6cd-48a8-b2d5-e6ab2b5305f8]
16:43:45.691 [ERROR] [ort.modbus.internal.ModbusManagerImpl] - Last try 3 failed when executing request (ModbusReadRequestBlueprint@1774abc[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=100,length=1,maxTries=3]). Aborting. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: IOException CRC Error in received frame: 0 bytes: [operation ID cb0f871c-e6cd-48a8-b2d5-e6ab2b5305f8]
16:43:46.000 [DEBUG] [dbus.handler.ModbusPollerThingHandler] - Thing modbus:poller:localSerial:fan received response PollResult(failure=AsyncModbusReadResult(request = ModbusReadRequestBlueprint@1774abc[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=100,length=1,maxTries=3], error = ModbusSlaveIOException(cause=ModbusIOException, EOF=false, message='I/O exception: IOException CRC Error in received frame: 0 bytes: ', cause2=null)))
Things
Bridge modbus:serial:localSerial [port="/dev/ttyUSB0", id=1, baud=9600, stopBits="1", parity="even", dataBits=8, encoding="rtu"]
Bridge poller fan [ start=100, length=1, refresh=20000, type="holding" ] {
Thing data VV_FanSpeed [ readStart="100", readValueType="int16", writeStart="100", writeValueType="int16", writeType="holding"]
Bridge poller temp [ start=206, length=12, refresh=60000, type="holding" ] {
Thing data VV_TempLevel [ readStart="206", readValueType="int16", writeStart="206", writeValueType="int16", writeType="holding"]
Thing data VV_TempSetpoint [ readStart="207", readValueType="int16"]
Thing data VV_TempLVL1 [ readStart="208", readValueType="int16"]
Thing data VV_TempLVL2 [ readStart="209", readValueType="int16"]
Thing data VV_TempLVL3 [ readStart="210", readValueType="int16"]
Thing data VV_TempLVL4 [ readStart="211", readValueType="int16"]
Thing data VV_TempLVL5 [ readStart="212", readValueType="int16"]
Thing data VV_TempSupplyAir [ readStart="213", readValueType="int16"]
Thing data VV_TempExtractAir [ readStart="214", readValueType="int16"]
Thing data VV_TempExhaustAir [ readStart="215", readValueType="int16"]
Thing data VV_ProtectionSensor [ readStart="216", readValueType="int16"]
Thing data VV_TempOutdoor [ readStart="217", readValueType="int16"]
