Platform information:
- Hardware: Raspberry Pi 4, 8GB
- OS:Debian 1:6.6.31-1+rpt1 (2024-05-29) aarch64 GNU/Linux
- Java Runtime Environment: 17.0.13
- openHAB version: 4.2.2
Issue of the topic: Error doing a fresh install of 4.2.2 using Raspberry Pi Imager.
I was able to generate the Boot SD using Raspberry Pi Imager on a Mac.
The SD boots correctly but at first time it didn´t start OpenHAB
Then I executed openhabian-config unattended
After the log viewer starts in port 9001 and I can see that OpenHab is not able to start due to Can’t get a WebContainer service from {org.osgi.service.http.HttpService -
If logs where generated please post these here using code fences:
2024-11-01 18:52:27.922 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.2.2 (Release Build)
2024-11-01 18:53:00.780 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2024-11-01 18:53:11.580 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2024-11-01 18:53:25.519 [WARN ] [service.spi.util.WebContainerManager] - Can't get a WebContainer service from {org.osgi.service.http.HttpService, org.ops4j.pax.web.service.WebContainer}={org.ops4j.pax.web.log.ncsa.extended=true, org.ops4j.pax.web.ssl.keystore.password=********, service.scope=bundle, org.ops4j.pax.web.ssl.key.password=********, org.ops4j.pax.web.session.cookie.name=JSESSIONID, org.osgi.service.http.connector.name=default, org.ops4j.pax.web.enc.iterationcount=1000, org.ops4j.pax.web.log.ncsa.file=yyyy_mm_dd.request.log, org.ops4j.pax.web.server.eventDispatcherThreadCount=1, org.osgi.service.http.checkForwardedHeaders=false, org.ops4j.pax.web.enc.suffix=), org.ops4j.pax.web.digestAuth.maxNonceAge=60000, org.ops4j.pax.web.ssl.ciphersuites.included=, org.ops4j.pax.web.session.url=jsessionid, org.ops4j.pax.web.formAuth.errorRedirect=false, org.ops4j.pax.web.ssl.ciphersuites.excluded=^.*_(MD5|SHA|SHA1)$,^TLS_RSA_.*$,^SSL_.*$,^.*_NULL_.*$,^.*_anon_.*, org.ops4j.pax.web.enc.prefix=ENC(, org.ops4j.pax.web.server.maxThreads=50, org.ops4j.pax.web.validatePeerCerts=false, service.id=160, org.ops4j.pax.web.session.cookie.maxAge=-1, org.ops4j.pax.web.ssl.truststore.password=********, org.ops4j.pax.web.ssl.session.cacheSize=-1, org.ops4j.pax.web.ssl.truststore.type=JKS, org.ops4j.pax.web.ssl.keystore.type=JKS, org.ops4j.pax.web.ssl.session.enabled=true, org.ops4j.pax.web.ssl.protocol=TLSv1.3, org.osgi.service.http.port=8080, org.ops4j.pax.web.log.ncsa.file.date.format=yyyy-MM-dd, org.ops4j.pax.web.ssl.renegotiationLimit=-1, org.osgi.service.http.secure.enabled=true, org.osgi.service.http.enabled=true, org.ops4j.pax.web.server.idleTimeout=300000, org.ops4j.pax.web.log.ncsa.retaindays=90, org.ops4j.pax.web.log.ncsa.logtimezone=GMT, org.ops4j.pax.web.enc.algorithm=PBEWithHmacSHA256AndAES_128, org.ops4j.pax.web.validateCerts=false, org.ops4j.pax.web.config.files=/usr/share/openhab/runtime/etc/jetty.xml, org.ops4j.pax.web.ssl.renegotiationAllowed=true, org.ops4j.pax.web.digestAuth.maxNonceCount=1024, org.ops4j.pax.web.enableOCSP=false, org.ops4j.pax.web.ssl.clientauth.needed=false, org.ops4j.pax.web.enc.enabled=false, org.osgi.service.http.port.secure=8443, javax.servlet.context.tempdir=/var/lib/openhab/tmp, org.ops4j.pax.web.enableCRLDP=false, org.ops4j.pax.web.server.connector.idleTimeout=30000, org.ops4j.pax.web.session.timeout=10, org.ops4j.pax.web.ssl.clientauth.wanted=false, org.ops4j.pax.web.ssl.protocols.excluded=SSL,SSLv2,SSLv2Hello,SSLv3, service.bundleid=232, org.ops4j.pax.web.server.minThreads=2, org.ops4j.pax.web.session.cookie.secure=false, org.ops4j.pax.web.enc.masterpassword=********, org.ops4j.pax.web.log.ncsa.append=true, org.osgi.service.http.secure.connector.name=secureDefault, org.ops4j.pax.web.ssl.session.timeout=-1, org.ops4j.pax.web.listening.addresses=0.0.0.0, org.ops4j.pax.web.log.ncsa.buffered=true, org.ops4j.pax.web.session.cookie.sameSite=unset, org.ops4j.pax.web.log.ncsa.enabled=false, org.ops4j.pax.web.ssl.protocols.included=, org.ops4j.pax.web.session.cookie.httpOnly=true, org.ops4j.pax.web.server.showStacks=false}
