Hello
I have Openhab 2.5.2 (openhabian) on RPi 3 B+.
I have been using ebus binding 1.4.1 (installed in Paper UI) with Esera USB Coupler with Vaillant VR430 and this was working but some queue problems occured. I decided to upgrade to last version binding 2.5.1.6 and perform manual installation by copying the org.openhab.binding.ebus-2.5.1-6.kar
into the /usr/share/openhab2/addons/
directory
After performing few sudo systemctl stop/clean-cache/start/shutdown the ebus 2.5.6.1 binding works (I can see valid data for an initial parameter) !
So ebus binding 2.5.6.1 is working but I am chasing for an error repeating every minute
2020-04-26 23:07:05.512 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-ebus'
Can smb help me to get rid if this error?
I have deactivated (rename) services/ebus.cfg
file (neded for ebus 1.4.1 binding) and deleted var/lib/openhab2/config/org/openhab/ebus.config
file (there is a new file now generated by system after restart)
services/addons.cfg file
binding = astro,modbus,ntp,rfxcom,squeezebox,wifiled,ebus,epsonprojector1
*view from the Karaf console
openhab> bundle:list | grep -i ebus
205 x Active x 80 x 1.0.6.202002091840 x eBUS library configuration
206 x Active x 80 x 1.0.6.202002091840 x eBUS core library
208 x Active x 80 x 2.5.1.202002091841 x openHAB Add-ons :: Bundles :: eBUS Binding
openhab> feature:list | grep -i ebus
openhab-binding-onebusaway x 2.5.3 x x Uninstalled x openhab-addons-2.5.3 x OneBusAway Binding
openhab-binding-ebus1 x 1.14.0 x x Uninstalled x openhab-addons-2.5.3 x eBUS Binding
ebus-binding x 2.5.1.6 x x x Started x ebus-distro-2.5.1-6 x eBUS 2.0 bindi
the ebus-binding was marked as Uninstalled initially and I perfmed command:
featue:install ebus-binding
so that the status now is Started, but the Error repeats.after rebooting.
I am a bit confused how to proceed further?
