Error in createTimer: org.quartz.core.JobRunShell & org.quartz.core.ErrorLogger
I don’t understand this error.
rule "Test1"
    Item V_balk_komn_lev received update
    TimerEnd.postUpdate("ON")
    val myTimer = createTimer(now.plusSeconds(5), [|
        TimerEnd.postUpdate("OFF")
        myTimer = null
2020-12-12 15:32:32.903 [vent.ItemStateChangedEvent] - V_balk_komn_lev changed from OFF to ON
2020-12-12 15:32:32.922 [vent.ItemStateChangedEvent] - TimerEnd changed from OFF to ON
2020-12-12 15:32:37.953 [vent.ItemStateChangedEvent] - TimerEnd changed from ON to OFF
2020-12-12 15:32:37.938 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.Timer 17 2020-12-12T15:32:37.933+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  <XFeatureCallImplCustom>.postUpdate(<XStringLiteralImpl>)
  <null>.myTimer = <XNullLiteralImplCustom>
} ] threw an unhandled Exception:
java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid:  (eProxyURI: telegram.rules#|::0.2.3.2.0.1.2.6.1.1.0.1::0::/1)
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.assignValueTo(XbaseInterpreter.java:1314) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:1302) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy197.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [bundleFile:?]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
2020-12-12 15:32:37.968 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 17 2020-12-12T15:32:37.933+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
Caused by: java.lang.IllegalArgumentException: Couldn't invoke 'assignValueTo' for feature JvmVoid:  (eProxyURI: telegram.rules#|::0.2.3.2.0.1.2.6.1.1.0.1::0::/1)
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
Hasn’t myTimer to be a global variable ?
What is the point of setting the timer to null?
There are many such examples in the community.openhab.org
Yes, but you have not followed the examples.
val myTimer = createTimer(now.plusSeconds( ...
This creates a timer to run in the future, and keeps a reference or handle for it in your variable myTimer.
Then your rule ends, and any variables created within it are discarded and destroyed. Variable myTimer no longer exists.
Some time later, your timer runs.
myTimer = null
That line fails because variable myTimer does not exist.
Just as @Wolfgang_S said, if you want to do this kind of thing you will need to use a global variable, which are defined and created outside of any rule.
Deleting the line “myTimer = null” didn’t help.
2020-12-15 23:37:00.548 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.Timer 5 2020-12-15T23:37:00.546+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  val sendTelegramAction
	at org.eclipse.smarthome.model.script.engine.ScriptError.<init>(ScriptError.java:65) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:140) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:991) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:954) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:235) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1205) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1135) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:861) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
	at com.sun.proxy.$Proxy127.apply(Unknown Source) ~[?:?]
2020-12-15 23:37:00.576 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 5 2020-12-15T23:37:00.546+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
Caused by: java.lang.NullPointerException
	... 1 more
have you tried to make myTimer a global variable by putting
var Timer myTimer
in the first line of your rule file ?
But your timer code is now not what you showed us to begin with, is it?
The error message shows that your timer code now includes a line like
val sendTelegramAction ...
and that is failing.
It’s possible you’ve messed up the brackets and the timer code now accidentally includes parts of a following rule or something, but we can’t tell unless you show us what you are actually doing.
