- Platform information:
- Hardware: i3, 8gb RAM
- OS: Windows 10 64bit
- Java Runtime Environment: Version 8 update 181
- openHAB version: 2.5.2
Since I have upgraded to 2.5.2 I get this error in Karaf and can’t do anything else:
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.util.ArrayList.grow(Unknown Source)
at java.util.ArrayList.ensureExplicitCapacity(Unknown Source)
at java.util.ArrayList.ensureCapacityInternal(Unknown Source)
at java.util.ArrayList.add(Unknown Source)
at org.apache.felix.resolver.ResolverImpl$UsedBlames.addBlame(ResolverImpl.java:2224)
at org.apache.felix.resolver.ResolverImpl.addUsedBlame(ResolverImpl.java:1270)
at org.apache.felix.resolver.ResolverImpl.mergeUses(ResolverImpl.java:1093)
at org.apache.felix.resolver.ResolverImpl.mergeUses(ResolverImpl.java:1094)
at org.apache.felix.resolver.ResolverImpl.computeUses(ResolverImpl.java:849)
at org.apache.felix.resolver.ResolverImpl.access$500(ResolverImpl.java:36)
at org.apache.felix.resolver.ResolverImpl$6.run(ResolverImpl.java:1214)
at org.apache.felix.resolver.ResolverImpl$EnhancedExecutor$1.run(ResolverImpl.java:2495)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Exception in thread "pool-626-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception in thread "pool-627-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception in thread "pool-630-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "nioEventLoopGroup-8-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "Active Thread: Equinox Container: 28351048-0c53-4da1-a844-0b8a7aae07ad"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "encryption-3-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "fileinstall-D:\OpenHab2\openhab-2.4.0-SNAPSHOT\userdata/etc"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "sshd-SshServer[e79512]-timer-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-common-482"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-thingHandler-864"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-thingHandler-862"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "SocketListener(JmDNS-/192.168.0.111)"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "pool-2-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "Connector-Scheduler-c85a6d"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "SocketListener(DESKTOP-TFPJU1D.local.)"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "pool-635-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "openHAB-job-scheduler_QuartzSchedulerThread"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-discovery-3"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ZWaveReceiveInputThread"
Exception in thread "encryption-1-thread-1" Exception in thread "pool-633-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "Thread-15091"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "Session-HouseKeeper-16eda3b"
Exception in thread "pool-636-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "fileinstall-D:\OpenHab2\openhab-2.4.0-SNAPSHOT/addons"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "pool-639-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "pool-19-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "JmDNS(DESKTOP-TFPJU1D.local.).Timer"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "JmDNS(JmDNS-/192.168.0.111).Timer"
Exception in thread "pool-638-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception in thread "pool-640-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception in thread "OkHttp Dispatcher" java.lang.OutOfMemoryError: Java heap space
Exception in thread "pool-642-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "Timer-783"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "pool-11-thread-1"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-152"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-common-492"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-common-481"
Exception in thread "pool-644-thread-1" java.lang.OutOfMemoryError: Java heap space
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25881"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25879"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-149"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ESH-httpClient-openhabcloud-315"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-common-523"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ESH-httpClient-openhabcloud-317"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-150"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "JmDNS(DESKTOP-TFPJU1D.local.).State.Timer"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25325"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-21083"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25880"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25883"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-151"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-153"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ServletModel-12-148"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-78"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "ESH-httpClient-openhabcloud-316"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25882"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25986"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25987"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "qtp18724306-25988"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "JmDNS(JmDNS-/192.168.0.111).State.Timer"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "OH-OSGiEventManager"
Exception: java.lang.OutOfMemoryError thrown from the UncaughtExceptionHandler in thread "WindowsStreamPump"
