Hi Everyone,
I pulled down the 2.2b and after the Karaf / openHAB CLI pops up I get a message if I hit,
tab → Error executing command: / by zero
help → less: java.lang.ArithmeticException: / by zero
If I let it sit and try the portal it doesn’t load.
Stats
Host : Alpine 3.6
Java : openjdk version “1.8.0_131”
OpenJDK Runtime Environment (IcedTea 3.4.0) (Alpine 8.131.11-r2)
OpenJDK 64-Bit Server VM (build 25.131-b11, mixed mode)
OH : 2.2 #1133
Zulu and Oracle JRE’s have the GLIBC requirement which I’m trying to avoid. I’m aware that openJDK is listed as having some hiccups, no need to remind unless this particular hiccup is a proven one (or I can help test!).
Besides that, has anyone seen this before?
J
