Hi all,
I am using openhabian on OH 5.2.3.
After a router reboot I got this error in the log:
2026-10-25 19:38:49.928 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:38:49.930 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:38:49.932 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:38:55.367 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:38:55.369 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:38:55.372 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:00.778 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:39:00.780 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:00.782 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:06.199 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:39:06.200 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:06.203 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:11.607 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:39:11.609 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:11.611 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:17.016 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Error : org.openhab.binding.matter.internal.client.MatterRequestException: clear() is deprecated; use clearAll() instead
2026-10-25 19:39:17.018 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
2026-10-25 19:39:17.022 [INFO ] [.matter.internal.bridge.MatterBridge] - Matter Bridge State: Stopped
It appears every 5 seconds.
Apparently a function called in the matter code is deprecated?
How to solve it?
EDIT: after a restart of OH the bridge is RUNNING. But it means that if the router reboots, the bridge stops?
