Hey All,
i just upgrade to the latest snapshot build and (I guess but not sure) since then the discovering by Alexa throws the following error. Furthermore new devices were not found by Echo (Alexa). However, switching the existing devices still works. The new devices show up on Homekit, so the syntax seems to be correct.
Update: As soon as I start a discovery, Log throws the error and PaperUI or anything else is not accessible anymore. Only restart, tmp deletion and restart helps to recover.
Error:
2018-12-07 22:12:54.788 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: org.eclipse.jetty.io.EofException
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:804) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:538) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:795) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:846) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:240) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:216) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:515) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:325) ~[?:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[?:?]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:116) ~[?:?]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[?:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[?:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:266) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
... 53 more
Thanks in advance! If there is any information missing, please let me know.
Kind regards
Patrick
