Hi there,
I’ve been using Openhab 2.2 with Z-Wave for a couple of months now. I had a couple of z-wave devices connected (mostly Fibaro switches, dimmers and wallplugs).
Then I tried to setup a Fibaro Universal Sensor, which never worked the way I wanted it to. Long story short, I made a hard reset on my Z-Wave controller and the nightmare began ![]()
I have a very big problem to reinclude my devices. Mostly I get the following errors (regardless which zwave device I try to include). I first made a hard reset and then I tried to include the first device (which has been excluded and/or resetted just before).
2018-04-04 20:49:17.741 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2018-04-04 20:49:17.745 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2018-04-04 20:49:17.747 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2018-04-04 20:49:17.750 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2018-04-04 20:49:17.752 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 1
2018-04-04 20:49:17.754 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2018-04-04 20:50:35.683 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: setupNetworkKey useSchemeZero=false
2018-04-04 20:50:36.108 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:c61532e6:node2' to inbox.
2018-04-04 20:50:36.127 [WARN ] [rialmessage.IdentifyNodeMessageClass] - Got IdentifyNodeMessage without request, ignoring. Last message was SendData.
2018-04-04 20:50:41.175 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: setupNetworkKey useSchemeZero=true
2018-04-04 20:50:41.179 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: Using Scheme0 Network Key for Key Exchange since we are in inclusion mode.
2018-04-04 20:50:41.291 [INFO ] [curityCommandClassWithInitialization] - NODE 2: Setting Network Key to real key after SECURITY_NETWORK_KEY_SET
2018-04-04 20:50:41.293 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: setupNetworkKey useSchemeZero=false
2018-04-04 20:50:41.364 [ERROR] [col.security.ZWaveSecureNonceTracker] - NODE 2: SECURITY_ERROR Device message contained nonce that is unknown to us, id=69.
2018-04-04 20:50:41.432 [WARN ] [mmandclass.ZWaveSecurityCommandClass] - NODE 2: payloadQueue was empty, returning!
What does this error message mean? What do I have to do to get it back running again? In this case I tried to add a Fibaro Wall plug which worked fine until I made this first reset.
Can someone please help me?
Thanks a lot in advance!
