[ERROR] [jersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream
as you maybe already recognized, i am cleaning up my openhab installation a litte bit :slight_smile:
So here is my next - and hopefully last - error message from my logs:
I really dont know where its comming from and what i got to do - would be happy if you could help me to solve the problem.
23:15:28.703 [ERROR] [jersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [173:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [174:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [171:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [171:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [171:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [171:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [171:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [86:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [86:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [187:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [83:org.eclipse.jetty.security:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [187:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [86:org.eclipse.jetty.servlet:9.3.21.v20170918]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [187:org.ops4j.pax.web.pax-web-jetty:6.0.9]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.Server.handle(Server.java:534) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [89:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.eclipse.jetty.io.EofException
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:199) ~[78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:420) ~[78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313) ~[78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:147) ~[78:org.eclipse.jetty.io:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:731) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) ~[89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) ~[89:org.eclipse.jetty.util:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:519) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:745) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:801) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:235) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:219) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:496) ~[85:org.eclipse.jetty.server:9.3.21.v20170918]
        at java.io.OutputStream.write(OutputStream.java:75) ~[?:?]
        at org.glassfish.jersey.servlet.internal.ResponseWriter$NonCloseableOutputStreamWrapper.write(ResponseWriter.java:320) ~[?:?]
        at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:218) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:294) ~[?:?]
        at org.eclipse.smarthome.io.rest.core.internal.GsonProvider.writeTo(GsonProvider.java:71) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[?:?]
        at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[?:?]
        at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
        at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
        ... 46 more
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
        at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
        at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
        at sun.nio.ch.IOUtil.write(IOUtil.java:148) ~[?:?]
        at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504) ~[?:?]
        at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:179) ~[78:org.eclipse.jetty.io:9.3.21.v20170918]
        ... 46 more
23:15:28.785 [ERROR] [jersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
        ... 46 more
        ... 46 more
thanks a lot!
Alex
DId you ever get to the bottom of this?
I’m interested in this as well as I have the same error. It appears when interacting with the IOS app.
So any suggestions are welcome
I saw the same message this morning in my logs. (openHAB 2.3.0 Build #1260)
I get this error sometimes too.
It happens when I have a UI opened in a browser or the android app. AND I restart openHAB. AND then refresh one of the UIs
Only happens once. After re-connection with UI, OH is fine again.
in my case Openhab, I don’t think that openhab was restarted this morning.
Where can I check this to be sure?
I think it is related to UIs
Try opening and closing HABpanel several times
I don’t have HABpanel installed.
yes opening and closing the IOS app, does this.
Any other UI then… I am not sure. I see it when http streams get interrupted and/or started when I close or start a UI. Usually HABpanel.
I see this error when I switch my screen off on the Ios app before the application could receive feedback. I have not tested it but I will presume it’s the same on the android app. I’m sure this error is just to inform you that the device OpenHAB was communicating with went away before it could finish. Personally I think this should not be a error but rather a INFO with a more descriptive message.
or even better a WARN or a DEBUG message :slight_smile:
with INFO you will see it in your logs
Got it since 2.5.6… Anyone else?
Same error for me. I saw in another thread to remove addons.config (located here: /var/lib/openhab2/config/org/openhab/addons.config and restart Openhab to let the file rebuilt by itself. Could be related to an old configuration. I’m trying it this morning. I’ll take a look into my log file tomorrow to see what happen.
Tried your hint and it seems to be not a solution. What is different in that version to the one before?
