Error ....list index out of range
Continuing the discussion from Intertechno LAN gateway:
Hallo,
i execuded your instructions, but when i turned on the switch i got this error:
“Traceback (most recent call last): File “/opt/openhab/customfiles/senditgw433.py”, line 62, in if sys.argv[3]==“on”:Toggle=ToggleOn IndexError: list index out of range”
#!/usr/bin/python
import socket
import sys
UDP_IP="10.0.0.47"
UDP_PORT=49880
#################### Basic values ########################
lo="4,"
hi="12,"
seqLo="4,12,4,12," # lo + hi + lo + hi
seqFl="4,12,12,4," # lo + hi + hi + lo
h="4,12,12,4," #=seqFl
l="4,12,4,12," #=seqLo
ToggleOn="4,12,12,4,4,12,12,4," # =h + h
ToggleOff="4,12,12,4,4,12,4,12," # =h + l
additional="4,12,4,12,4,12,12,4," # =l + h
headITGW="0,0,6,11125,89,26,0,"
tx433version="1,"
sPeedITGW="125,"
#tailITGW="1,125,0"# =tx433version + ',' + sPeedITGW + "0"
tailITGW=tx433version + sPeedITGW + "0"
#################### Master########################
if sys.argv[1]=="A":Master=(l + l + l + l)
elif sys.argv[1]=="B":Master=(h + l + l + l)
elif sys.argv[1]=="C":Master=l + h + l + l
elif sys.argv[1]=="D":Master=h + h + l + l
elif sys.argv[1]=="E":Master=l + l + h + l
elif sys.argv[1]=="F":Master=h + l + h + l
elif sys.argv[1]=="G":Master=l + h + h + l
elif sys.argv[1]=="H":Master=h + h + h + l
elif sys.argv[1]=="I":Master=l + l + l + h
elif sys.argv[1]=="J":Master=h + l + l + h
elif sys.argv[1]=="K":Master=l + h + l + h
elif sys.argv[1]=="L":Master=h + h + l + h
elif sys.argv[1]=="M":Master=l + l + h + h
elif sys.argv[1]=="N":Master=h + l + h + h
elif sys.argv[1]=="O":Master=l + h + h + h
elif sys.argv[1]=="P":Master=h + h + h + h
#################### Slave########################
if sys.argv[2]=="1":Slave=l + l + l + l
elif sys.argv[2]=="2":Slave=h + l + l + l
elif sys.argv[2]=="3":Slave=l + h + l + l
elif sys.argv[2]=="4":Slave=h + h + l + l
elif sys.argv[2]=="5":Slave=l + l + h + l
elif sys.argv[2]=="6":Slave=h + l + h + l
elif sys.argv[2]=="7":Slave=l + h + h + l
elif sys.argv[2]=="8":Slave=h + h + h + l
elif sys.argv[2]=="9":Slave=l + l + l + h
elif sys.argv[2]=="10":Slave=h + l + l + h
elif sys.argv[2]=="11":Slave=l + h + l + h
elif sys.argv[2]=="12":Slave=h + h + l + h
elif sys.argv[2]=="13":Slave=l + l + h + h
elif sys.argv[2]=="14":Slave=h + l + h + h
elif sys.argv[2]=="15":Slave=l + h + h + h
elif sys.argv[2]=="16":Slave=h + h + h + h
#################### Toggle ########################
if sys.argv[3]=="on":Toggle=ToggleOn
elif sys.argv[3]=="off":Toggle=ToggleOff
# MESSAGE=headITGW + Master+ Slave+ additional + on/off + tailITGW
MESSAGE=headITGW + Master+ Slave+ additional + Toggle + tailITGW
print "UDP target IP:", UDP_IP
print "UDP target port:", UDP_PORT
print "message:", MESSAGE
sock =socket.socket(socket.AF_INET, # Internet
 socket.SOCK_DGRAM) # UDP
sock.sendto(MESSAGE, (UDP_IP, UDP_PORT))
The original thread shows 3 arguments passed to the python script.
You didn’t show the command you’re executing, but it appears to not be passing 3 arguments.
intertechno.things
exec:command:intertechnoP16 [command="/usr/bin/python /opt/openhab/customfiles/send2itgw433.py P 16 on", interval=0, timeout=5, autorun=true]
exec:command:intertechnoP14 [command="/usr/bin/python /opt/openhab/customfiles/send2itgw433.py P 14 off", interval=0, timeout=5, autorun=true]
intertechno.items
String IntertechnopP16		"Drucker"		        <button>	(InitOO2)	{channel="exec:command:intertechnoP16:input", autoupdate="true"}
String IntertechnoP14		"Sternenkette"			<button>				{channel="exec:command:intertechnoP14:input", autoupdate="true"}
send2itgw433.py
#!/usr/bin/python
import socket
import sys
UDP_IP="10.0.0.47"
UDP_PORT=49880
lo="4,"
hi="12,"
h="4,12,12,4,"   #= seqFl
l="4,12,4,12,"   #= seqLo
ToggleOn= "4,12,12,4,4,12,12,4," #= h + h
ToggleOff="4,12,12,4,4,12,4,12," #= h + l
additional="4,12,4,12,4,12,12,4," #= l + h
headITGW= "0,0,6,11125,89,26,0,"
tx433version= "1,"
sPeedITGW="125,"
#tailITGW="1,125,0"  #= tx433version + ',' + sPeedITGW + "0"
tailITGW= tx433version + sPeedITGW + "0"
#################### Master ########################
if sys.argv[1]== "A":Master= l + l + l + l
elif sys.argv[1]== "B":Master= h + l + l + l
elif sys.argv[1]== "C":Master= l + h + l + l
elif sys.argv[1]== "D":Master= h + h + l + l
elif sys.argv[1]== "E":Master= l + l + h + l
elif sys.argv[1]== "F":Master= h + l + h + l
elif sys.argv[1]== "G":Master= l + h + h + l
elif sys.argv[1]== "H":Master= h + h + h + l
elif sys.argv[1]== "I":Master= l + l + l + h
elif sys.argv[1]== "J":Master= h + l + l + h
elif sys.argv[1]== "K":Master= l + h + l + h
elif sys.argv[1]== "L":Master= h + h + l + h
elif sys.argv[1]== "M":Master= l + l + h + h
elif sys.argv[1]== "N":Master= h + l + h + h
elif sys.argv[1]== "O":Master= l + h + h + h
elif sys.argv[1]== "P":Master= h + h + h + h
#################### Slave ########################
if sys.argv[2]== "1":Slave= l + l + l + l
elif sys.argv[2]== "2":Slave= h + l + l + l
elif sys.argv[2]== "3":Slave= l + h + l + l
elif sys.argv[2]== "4":Slave= h + h + l + l
elif sys.argv[2]== "5":Slave= l + l + h + l
elif sys.argv[2]== "6":Slave= h + l + h + l
elif sys.argv[2]== "7":Slave= l + h + h + l
elif sys.argv[2]== "8":Slave= h + h + h + l
elif sys.argv[2]== "9":Slave= l + l + l + h
elif sys.argv[2]== "10":Slave= h + l + l + h
elif sys.argv[2]== "11":Slave= l + h + l + h
elif sys.argv[2]== "12":Slave= h + h + l + h
elif sys.argv[2]== "13":Slave= l + l + h + h
elif sys.argv[2]== "14":Slave= h + l + h + h
elif sys.argv[2]== "15":Slave= l + h + h + h
elif sys.argv[2]== "16":Slave= h + h + h + h
if sys.argv[3]== "on":Toggle= ToggleOn
elif sys.argv[3]== "off":Toggle= ToggleOff
# MESSAGE= headITGW + master + slave + additional + on/off + tailITGW
MESSAGE= headITGW + Master + Slave + additional + Toggle + tailITGW
sock= socket.socket(socket.AF_INET, # Internet
this is the error:
Traceback (most recent call last): File “/opt/openhab/customfiles/send2itgw433.py”, line 62, in if sys.argv[3]== “on”:Toggle= ToggleOn IndexError: list index out of range Traceback (most recent call last): File “/opt/openhab/customfiles/send2itgw433.py”, line 62, in if sys.argv[3]== “on”:Toggle= ToggleOn IndexError: list index out of range
If you add this code above the first line in your “Toggle” block, you should be able to see the arguments the script is receiving.
index=0;
for larg in sys.argv:
  print "Arg", index, larg
  index = index+1
Also, you should check your thing definitions in the running OH instance to verify they match what you’ve shown is in your intertechno.things file.
thank you, now ist working! :wink:
