Error logging in to amazonechocontrol
I recently changed my amazon password.
I wanted to relogin to my amazon account using:
http://openhab:8080/amazonechocontrol/
If I click the link “Amazon Account” I see the following error:
HTTP ERROR 500 org.smarthomej.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.de/api/bootstrap' failed: Unauthorized
URI:	/amazonechocontrol/myaccount
STATUS:	500
MESSAGE:	org.smarthomej.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.de/api/bootstrap' failed: Unauthorized
SERVLET:	org.ops4j.pax.web.service.spi.model.ServletModel-51
CAUSED BY:	org.smarthomej.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.de/api/bootstrap' failed: Unauthorized
Caused by:
	at org.smarthomej.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:702)
	at org.smarthomej.binding.amazonechocontrol.internal.Connection.tryGetBootstrap(Connection.java:502)
	at org.smarthomej.binding.amazonechocontrol.internal.Connection.verifyLogin(Connection.java:927)
	at org.smarthomej.binding.amazonechocontrol.internal.AccountServlet.doGet(AccountServlet.java:280)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:791)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550)
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1435)
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1350)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82)
	at org.eclipse.jetty.server.Server.handle(Server.java:516)
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:383)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036)
	at java.base/java.lang.Thread.run(Thread.java:829)
Do I need to remove the old login information somehow before? 2fa is enabled.
Openhab Version is 3.1.1
To resolve login problems the connection settings of an account thing can be reset via the karaf console. The command amazonechocontrol listAccounts shows a list of all available account things. The command amazonechocontrol resetAccount <id> resets the device id and all other connection settings. After resetting a connection, a new login as described above is necessary.
