- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: Raspbian GNU/Linux 10 (buster)
- Java Runtime Environment: the one that comes with openHABian
- openHAB version: 3.2.0
- Issue of the topic: general system failure, see log
- If logs where generated please post these here using code fences:
2021-12-20 16:56:54.678 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-tr064, openhab-binding-dwdunwetter, openhab-misc-openhabcloud, openhab-binding-avmfritz, openhab-persistence-influxdb, openhab-binding-amazonechocontrol, openhab-binding-renault, openhab-binding-shelly, openhab-binding-harmonyhub, openhab-binding-netatmo, openhab-transformation-map, openhab-transformation-exec, openhab-binding-systeminfo, openhab-binding-dwdpollenflug, openhab-transformation-scale, openhab-binding-icalendar, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-binding-mystrom, openhab-binding-tankerkoenig, openhab-ui-basic, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-gardena, openhab-binding-astro, openhab-binding-icloud, openhab-binding-deutschebahn': Error:
Resource mvn:org.openhab.osgiify/org.json.json/20131018 does not contain a manifest
Resource mvn:org.openhab.addons.bundles/org.openhab.binding.netatmo/3.2.0 does not contain a manifest
System does not fully start. Installation failed. R.3.2.0-RC1 worked well. Upgraded using openhabian-config today which resulted in this failure.
Tried to install again, same effect
What to do to fix this?
